nse4-fgt-7-2 question 76 discussion
back to fortinet forum
Question 76
Refer to the exhibits.
Exhibit A shows system performance output. Exhibit B shows a FortiGate configured with the default configuration of high memory usage thresholds.
Based on the system performance output, which two results are correct? (Choose two.)
  • A. FortiGate will start sending all files to FortiSandbox for inspection.
  • B. FortiGate has entered conserve mode. Most Votes
  • C. Administrators cannot change the configuration. Most Votes
  • D. Administrators can access FortiGate only through the console port.
bd
0%
B 13 votes
52%
C 10 votes
40%
8%
javalcasan
1 year ago
Correct answers are B and C. D is incorrect, only happens when in extreme mode.
Saschbert
5 months, 3 weeks ago
D is not correct
facil
2 weeks, 5 days ago
