Refer to the exhibit. The exhibit shows the IPS sensor configuration. If traffic matches this IPS sensor, which two actions is the sensor expected to take? (Choose two.)
The sensor will gather a packet log for all matched traffic.
The sensor will reset all connections that match these signatures.
The sensor will block all attacks aimed at Windows servers.
The sensor will allow attackers matching the Microsoft Windows.iSCSI.Target.DoS signature.
ab
Saschbert
5 months ago
B is not correct
Want to join our community?
B is not correct
