nse4-fgt-7-2 question 5 discussion
back to fortinet forum
By default, FortiGate is configured to use HTTPS when performing live web filtering with FortiGuard servers.
Which CLI command causes FortiGate to use an unreliable protocol to communicate with FortiGuard servers for live web filtering?
  • A. set webfilter-force-off disable
  • B. set webfilter-cache disable
  • C. set protocol tcp
  • D. set fortiguard-anycast disable
deepz142
8 months, 3 weeks ago
D. set fortiguard-anycast disable -- here D is correct.
C. this option is wrong since protocol mentioned here is TCP. If protocol mentioned is UDP, then it would have been correct.
