Which statement is correct regarding the security fabric?
FortiManager is one of the required member devices.
FortiGate devices must be operating in NAT mode.
A minimum of two Fortinet devices is required.
FortiGate Cloud cannot be used for logging purposes.
0%
100%
0%
0%
deepz142
8 months ago
B is correct. FortiGate Security 7.2 Study Guide (p.428): "You must have a minimum of two FortiGate devices at the core of the Security Fabric, plus one FortiAnalyzer or cloud logging solution. FortiAnalyzer Cloud or FortiGate Cloud can act as the cloud logging solution. The FortiGate devices must be running in NAT mode."
Want to join our community?
