nse4-fgt-7-2 question 25 discussion
back to fortinet forum
Question 25
Based on the routing database shown in the exhibit, which two conclusions can you make about the routes? (Choose two.)
  • A. The port3 default route has the lowest metric.
  • B. The port1 and port2 default routes are active in the routing table.
  • C. The ports default route has the highest distance.
  • D. There will be eight routes active in the routing table.
cd
deepz142
6 months, 3 weeks ago
B and C is correct answer. The
better routes show an asterisk next to the route source to indicate they are FIB entries, and therefore, are used for routing traffic.
