nse4-fgt-7-2 question 104 discussion
back to fortinet forum
Question 104
The exhibit shows a diagram of a FortiGate device connected to the network and the firewall policy and IP pool configuration on the FortiGate device.
Two PCs, PC1 and PC2, are connected behind FortiGate and can access the internet successfully. However, when the administrator adds a third PC to the network (PC3), the PC cannot connect to the internet.
Based on the information shown in the exhibit, which three configuration changes should the administrator make to fix the connectivity issue for PC3? (Choose three.)
  • A. In the IP pool configuration, set type to overload. Most Votes
  • B. Configure 192.2.0.12/24 as the secondary IP address on port1.
  • C. In the firewall policy configuration, disable ippool.
  • D. In the IP pool configuration, set endip to 192.2.0.12. Most Votes
  • E. Configure another firewall policy that matches only the address of PC3 as source, and then place the policy on top of the list.
ade
A 33 votes
28%
B 7 votes
6%
C 18 votes
15%
D 36 votes
31%
E 20 votes
17%
ansari
1 year, 2 months ago
i think the answer is ADE
semartinez
12 months ago
Debe tener mas ip pool para poder navegar
sureyya.ayce
10 months, 2 weeks ago
a d and e are the answer
Ozzy_98
10 months, 1 week ago
The problem is the IP pool is set to 1 to 1, but there's only 2 IPs in the pool. So when a third connects, there is no more IPs in the pool. The rule itself is fine. Expand the pool, or switch to overload instead of 1 to 1.
evantoday
7 months, 1 week ago
Issam
1 month, 3 weeks ago
the answer is ACD
pjhun035
end ip must be increased so that PC3 can use NAT. Or we can set the type to overload so that it uses same ip address but different ports
