ns0-527 question 72 discussion
View all NetApp Certified Implementation Engineer - Data Protection Exam here
Question 72
Your customer wants to implement SVM DR, but the customer is not certain whether the identity-
preserve parameter should be enabled. The customer explains that the source and destination
clusters are in different network subnets.
In this scenario, which SVM DR solution should the customer use?
  • A. SVM DR using the identity-preserve parameter disabled and the default SnapMirror policy.
  • B. SVM DR using the identity-preserve parameter enabled and then administratively take the data LIFs offline on the DR cluster.
  • C. SVM DR with the identity-preserve parameter enabled and a SnapMirror policy with the discard- configs network parameter.
  • D. SVM DR with the identity-preserve parameter enabled and the default SnapMirror policy.
Guss
1 year, 5 months ago
C discard network to true
