ns0-527 question 1 discussion
View all NetApp Certified Implementation Engineer - Data Protection Exam here
Your manager requires you to protect a production SVM called svm01 by using SVM-DR. Your
manager insists that all configuration and data LUNs be replicated to the DR cluster. The destination
SVM should be called drsvm01. You set up an SVM-DR relationship between the clusters, specifying
that the identity- preserve option is set to true. After the initial replication completes, you discover
that the iSCSI LIF configuration has not been replicated to drsvm01.
What should you do to solve this problem?
  • A. Run the relationship a second time and check the configuration again.
  • B. Manually create and configure the iSCSI LIFs on drsvm01.
  • C. Set up a new relationship without using the -identity-preserve option.
  • D. Add the FC protocol to the destination and configure the FC LIFs.
Guss
1 year, 8 months ago
No SAN LIF not replicated. Choose B
