mcd-level-1 question 74 discussion
back to mulesoft forum
Question 74
Refer to the exhibits.
The Set Payload transformer In the addltem subflow uses DataWeave to create an order object.
What is the correct DataWeave code for the Set Payload transformer in the createOrder flow to use
the addltem subflow to add a router cable with the price of 100 to the order?
  • A. addltemf { payload: { price: "100", item: "router", itemType: "cable" } > )
  • B. lookupf "addltem", { payload: { price: "100", item: "router", itemType: "cable" } } )
  • C. addltemf { price: "100", item: "router", itemType: "cable" })
  • D. lookupf "addltem", { price: "100", item: "router", itemType: "cable" } )
galibakravan
10 months, 2 weeks ago
Correct Answer is D
