hpe2-t37 question 6 discussion
back to hp forum
Your customer asks you if it is possible to perform HPE Synergy initial setup remotely. How should
you respond?
  • A. Remote HPE Synergy setup is possible if HPE Composer 2 is used and a DHCP server Is available in the management network.
  • B. Remote HPE Synergy Installation can be done only if an additional set of the services was purchased together with hardware platform.
  • C. HPE Synergy cannot be deployed remotely, as Initial setup must be performed using a local console connection.
  • D. HPE Synergy can be configured remotely through a secure connection to the FLM if this option was enabled In the factory.
HPE Synergy 4-port Frame Link Modules have SFP+ ports which enable connections to distant frames
and remote subnets.
https://cdn.cnetcontent.com/syndication/feeds/hp-ent/inline-
content/S6/5/0/5029A837AB821E112E962CFFA2E59E065568F85E_source.PDF
cassucena
1 year, 7 months ago
A is correct
