ServiceNow cis-vr practice test
Certified Implementation Specialist - Vulnerability Response Exam
Last exam update: Sep 06 ,2025
What is the best way to develop a complete list of Vulnerability Reports?
  • A. Recommend that the client purchase the full Performance Analytics package.
  • B. Ask the CISO.
  • C. Work with the customer to identify the things that will be most useful to them. Most Votes
  • D. Use the standard out of the box reports only.
B 3 votes
C 15 votes
zqadora1
8 months, 3 weeks ago
zqadora1
The best way to develop a complete list of Vulnerability Reports is to collaborate with the customer, like tailoring a suit to fit their specific needs and preferences.
ana.cristina.costa
6 months, 1 week ago
The three levels of users you will likely encounter that will need access to data displayed in the
Vulnerability Response dashboard are: Choose 3 answers
  • A. Security Analysts Most Votes
  • B. Customers
  • C. CIO/CISO
  • D. Fulfillers
A 15 votes
B 10 votes
C 15 votes
D 10 votes
zqadora1
Think of the three levels of users as a pyramid: Security Analysts at the bottom, Customers in the middle, and CIO/CISO at the top, each needing access to the Vulnerability Response dashboard.
What type of data would the CIO/CISO want on the dashboard?
  • A. Aggregations for priority and workload
  • B. Drill-down to granularity
  • C. Single, clear indicators of organizational health Most Votes
  • D. Up to the minute views
A 4 votes
C 12 votes
zqadora1
The CIO/CISO would want single, clear indicators of organizational health on the dashboard, like a traffic light system showing green for good and red for bad to quickly assess the situation.
ana.cristina.costa
To get useful reporting regarding the most vulnerable CI's, which statement applies?
  • A. You must purchase a separate PA module.
  • B. Your CI population must be huge.
  • C. You must have good KPi's defined.
  • D. Your CMDB must be up to date and useful. Most Votes
D 12 votes
zqadora1
To effectively report on the most vulnerable Configuration Items (CIs), think of your CMDB as a well-organized library; if it's up-to-date, you can easily find and assess the most critical books (CIs).
Managers should have access to which role-based data access and visualizations? Choose 3 answers
  • B. Time period views Most Votes
  • C. Up-to-the-minute views
  • D. Drill-down to granularity
A 10 votes
B 11 votes
C 5 votes
D 10 votes
zqadora1
Managers need access to summarized data for priorities (A), historical trends (B), and detailed insights (D) to make informed decisions, like using a telescope for big picture views and a microscope for details.
What role Is required to view the Vulnerability Overview Dashboard?
  • A. sn_vuI.vulnerability.read Most Votes
  • B. sn_vuI.manager
  • C. sn_vul.ciso
  • D. sn_vul.vulnerability.wnte
A 12 votes
Storla
9 months, 1 week ago
"sn_vuI.vulnerability.read" and "sn_vuI.vulnerability.write" is deprecated, use "sn_vul.read_all" and "sn_vul.vulnerability_analyst" respectively.
zqadora1
To view the Vulnerability Overview Dashboard, you need the role "sn_vul.vulnerability.read"
To ensure that Vulnerabilities are processed correctly, you can define a Service Level Agreement
(SLA) for Vulnerability Response. To achieve this you would:
  • A. Create a custom workflow to monitor the time between States
  • B. Log in as a system admin, and using the globally scoped baseline SLA Modules
  • C. Have the role of Vulnerability admin, but only in the Vulnerability Scope
  • D. Make sure you have at least the sn_vul.vulnerability_write role and using the baseline SLA Application Modules
B 4 votes
C 5 votes
zqadora1
To ensure vulnerabilities are handled correctly, you need the sn_vul.vulnerability_write role and baseline SLA Application Modules
Which of the following best describes the Vulnerable item State Approval Workflow?
  • A. It is read-only, you can only change the Assignment Group members for the approval
  • B. It exists in the Security Operations Common scope so it can be modified by any Security Operations Admin
  • C. It can only be modified by System Adminstrators
  • D. It runs against the [sn_vul_change_approval] table
D 7 votes
aaryan0099
1 year, 1 month ago
D is correct answer
What is the ServiceNow application used for process automation?
  • A. Knowledge Base
  • B. Workflows
  • C. SLAs
  • D. Service Catalog
B 9 votes
Which of the following is a common Integration point between Vulnerability and GRC?
  • A. Security Incident Response
  • B. Change
  • C. Problem
  • D. Risk Indicators
D 8 votes
A common Integration point with Vulnerability is:
  • A. Workflow Mappings
  • B. Risk Indicators within GRC Most Votes
  • C. Service Catalog
  • D. Knowledge Base
B 11 votes
If fixing a Vulnerable Item outweighs the benefits, the correct course of action is:
  • A. Mark the CI inactive in the CMDB and notify the CI owner
  • B. Record the accepted risk and Close/Defer the Vulnerable Item
  • C. Deprioritize the Vulnerable item Records (VlT) to push them further down the list so it can be ignored
  • D. Add the Cl to the Vulnerability Scanners exclusions Related List
B 7 votes
Filter groups can be used In Vulnerability Response to group what type of vulnerability records?
  • A. Vulnerability groups
  • B. Third Party Entries
  • C. Vulnerable Items
  • D. Vulnerable Software
C 9 votes
Which of the following can NOT be used for building Vulnerability Groups?
  • A. Vulnerability
  • B. Filter Groups
  • C. Condition Builder
  • D. Advanced Scripts
D 7 votes
Where in the platform can you create Filter Groups?
  • A. Vulnerability > Administration > Filter Groups
  • B. Vulnerability > Groups > Filter Groups
  • C. Security Operations > Administration > Filter Groups
  • D. Security Operations > Groups > Filter Groups
C 3 votes
D 5 votes
