pmi pmi-acp practice test
PMI Agile Certified Practitioner
Last exam update: Apr 19 ,2025
Page 1 out of 48. Viewing questions 1-15 out of 717
What is the Agile term for the time period when some or all of the following occur: beta testing, regression testing, product
integration, integration testing, documentation, defect fixing?
  • A. Spike
  • B. Code Freeze
  • C. Tail
  • D. Lag
At a strategic level, what is the most appropriate way for an Agile team to estimate a project?
  • A. Creating a strategic plan by estimating hours and days required
  • B. Using an abstract measurement to estimate Product Backlog items
  • C. Estimating source lines of code needed to implement the features
  • D. Taking an initial set of estimates and adding an appropriate risk factor
A team identifies the number of threats and lists them in the order in which they were identified. After analyzing a cause-and-
effect diagram, the ownership of the threats and their treatment is assigned, and a number of risk cards are placed on the
Kanban board.
What approach should be used to manage these threats?
  • A. Create a risk register detailing the threats, their causes, and their treatment strategies; and complete ownership to provide tighter risk control and a stakeholder communication tool
  • B. Focus on the threats during the daily stand up and ensure they are visible to the entire team and other interested parties
  • C. Prioritize the risks based on their criticality and timing, and track actions to closure
  • D. Ensure that the prioritization of threats is complete, and that ownership actions are assigned and visible to everyone
With multiple Scrum teams, you should have a separate product backlog.
On Agile teams, conflict is to be avoided at all cost.
Which one is NOT one of the 5 common risk areas mitigated by Agile?
  • A. Intrinsic schedule flaw
  • B. Specification breakdown
  • C. Scope creep
  • D. Stakeholder apathy
  • E. Personnel loss
  • F. Productivity variation
The best reason for extreme character personas in writing user stories is to:
  • A. Identify errors in product design and testing.
  • B. Help identify user stories that would otherwise be missed.
  • C. Provide precision to support vague user concepts.
  • D. Provide value to the Sprint planning session.
Which technique is used by a project team to estimate the amount of work that can be done per iteration?
  • A. Velocity measurement
  • B. Relative prioritization
  • C. Planning Poker
  • D. Release planning
Scrum is a container for other techniques and methodologies.
Toward the end of a project, the product owner discovers that the project has a high probability of failure due to a critical
feature not functioning as expected.
What should the product owner do?
  • A. Terminate the project to cut losses
  • B. Review possible options and make an informed decision to cut losses based on delivered business value
  • C. Bring in experts to increase the probability of success
  • D. Continue the project, release the product without the failing feature, and fix the feature in a subsequent release
Setting up development work in a way that the team can figure out what to do next is called:
  • A. A pull system
  • B. Push system
  • C. Critical path
  • D. Sprint backlog
Select the statements that are TRUE about the Product Owner. (Choose two.)
  • A. The Product Owner can clarify the backlog during the Sprint
  • B. The Product Owner estimates the size of the Sprint backlog
  • C. The Product Owner prioritizes the Product backlog
  • D. The Product Owner defines the Sprint Goal before the Sprint Planning meeting
A C
The Product Owner does not have to be a single person but may be a committee or a shared responsibility between multiple
individuals.
An agile team discovers a new risk and identifies that its impact may be severe.
What should an agile practitioner recommend?
  • A. Add a goal to the current iteration to fully mitigate or control the risk.
  • B. Balance risk reduction and value adding activities in the next iteration.
  • C. Continue with the current plan to maintain team velocity.
  • D. Update the risk register and seek direction from a risk specialist.
Which is the first step in setting up Kanban?
  • A. Place prioritized goals on the left column of the board
  • B. Decide on limits for items in queue and work in progress
  • C. Map your current workflow
  • D. Lay out a visual Kanban board
