oracle 1z0-822 practice test
Oracle Solaris 11 Advanced System Administration
Last exam update: Aug 29 ,2026
Page 1 out of 10. Viewing questions 1-15 out of 140
A recursive snapshot was taken of the root pool and the snapshot streams are stored on a remote
system. The boot disk has failed, has been replaced, and the root pool snapshots have been restored.
Which two steps are still required to make the system bootable?
  • A. Re-create the swap and dump devices.
  • B. Install the boot blocks on the new disk.
  • C. Restore the snapshot stream.
  • D. Set the bootfs property on the root pool.
  • E. Perform a ZFS rollback to restore the file systems in the root pool.
C, E
Review the following output from the zpool status command:
Which three are true for pool1?
  • A. It this mirror is split, the new pool will contain disks c3t5d0 and c3t6d0.
  • B. If this mirror is split, by default the new pool will contain disks c3t3d0 and c3t5d0.
  • C. Data is striped across mirror-0 and mirror-1.
  • D. mirror-1 is a mirrored copy of data that is stored on mirror-0.
  • E. Disk c3t3d0 is a mirrored copy of disk c3c4d0.
  • F. If this mirror is split, pool1 will no longer be mirrored.
B, D, E
The zfs holds command displays the following information:
Which two statements are true?
  • A. Use zfs destroy –d pool12/data@nov to destroy the snapshot immediately.
  • B. Attempts to destroy the snapshot using zfs destroy pool12/data@nov will fail.
  • C. Attempts to destroy the pool12/data@nov snapshot will not destroy the snapshot immediately.
  • D. The zfs directory –R pool12/data command will destroy the file system immediately.
  • E. The defer_destroy property is set to on for the pool12/data@nov data set.
  • F. The userrefs property is set to 1 (or higher) for the pool12/data@nov data set.
C, E
Consider the following ZFS configuration:
You have created snapshots of the homo directories which are as follows:
You have another storage pool named bpool on the same system. You use the following command to
store the snapshots in this pool:
# zfs send rpool/export/[email protected] | zfs recv f [email protected]
What will be created in the pool bpool as a result of this operation?
Consider the following commands on a newly installed system:
zfs set compression=on rpool
zfs get H 0 source compression rpool
What is the output of the second command?
  • A. default
  • B.
  • C. local
  • D. on
http://docs.oracle.com/cd/E19082-01/817-2271/gazuk/ (querying ZFS properties for scripting)
You want to create a ZFS file system with the following specifications:
lzjb compression enabled
Cannot consume more than 2 GB from the storage pool
Redundant data at the block level eliminated
Mounted as /data
Which command creates the desired file system?
  • A. zfs create o mountpoint=/data,compression=on,algorithm=lzjb,deduplication=on,quota=2g /pool1/data
  • B. zfs create o mountpoint=/data compression=on algorithm=lzjb deduplication=on quota=2g /pool1/data
  • C. zfs create –o mountpoint=/data –o compression=on –o dedup=on –o quota=2g /pool1/data
  • D. zfs create o mountpoint=/data o compression=on o algorithm=lzjb o deduplication=on o quota=2g /pool1/data
  • E. zfs create pool/data zfs set mountpoint=/data,quota=2g, dedup=on,compression=on /pool1/data
Which two zpool subcommands will permanently remove a submirror from active storage pool?
  • A. remove
  • B. detach
  • C. destroy
  • D. offline
  • E. replace
  • F. split
  • G. zpool does not permit this operation on an active storage pool unless the submirror faults.
G
G
Your task is to configure storage for an Oracle Solaris 11 system to support multiple web servers. Each
web server will be contained in a separate zone. The system has an attached disk array configured as
a JBOD (Just a Bunch Of Disks). The system also has an internal solid-state drive. The data accessed
through the websites will be primarily read-only. The web servers are expected to be very busy, so
configure the storage for maximum performance. Because the data is primarily static, but
redundancy is required to maintain high availability in the event of a hardware failure. Data does not
change often, but it is expected that the same data will be accessed many times throughout the day.
Which configuration option best meets the data storage requirements?
  • A. a raid2 storage pool with a separate log device
  • B. a mirrored storage pool with a separate cache device
  • C. a mirrored storage pool with a separate log device
  • D. a three disk striped storage pool with a separate cache device
  • E. a raidz1 storage pool with a separate log and cache device
The zpool configuration on serverA is:
pool 1
c3t2d0
c3t3d0
pool 2
c3t4d0
c3t5d0
The zpool configuration on servetB is:
pool1
mirror-0
c3t2d0
c3t3d0
mirror-1
c3t4d0
c3t5d0
Which option will modify the configuration on serverA to match serverB?
  • A. zpool destroy pool2 zpool attach pool1 c3t4d0 c3t5d0
  • B. zpool destroy pool2 zpool attach pool1 c3t2d0 c3t2d0 c3t4d0 c3t5d0
  • C. zpool destroy pool2 zpool add pool1 c3t4d0 c3t5d0
  • D. zpool destroy pool2 zpool mirror pool1 pool2
  • E. zpool destroy pool2 zpool attach pool1 c3t2d0 attach pool1 c3t3d0 zpool attach pool1 c3t4d0 attach pool1 c3t5d0
  • F. zpool destroy pool1 zpool destroy pool2 zpool destroy pool1 mirror c3t2d0 c3t3d0 c3t4d0 c3t5d0
Which is the result of the following command?
# zfs send i dpool/sales/qrreports@qtrreport dpool/sales/qrreports@mth3qtrreport
  • A. An error message will be sent to standard error.
  • B. The dpool/sales/qrreports@qtrreport snapshot is saved to disk.
  • C. The dpool/sales/qrreports@mth3qtrreport snapshot is saved to disk
  • D. The difference between the First snapshot and the second snapshot will be written to disk
You have a ZFS pool that contains a hierarchy of data file systems. You create snapshots of the file
systems and you created a clone (dpool/export/CID) of the dpool/export/home/CID file systems. The
file systems are as follows:
Now you remove a file from the cloned file system:
root@sll-server1:~# rm /export/CID/core.bash.8070
How will space usage be changed for dpool/export/CID?
  • A. The USED value will increase and the REFER value will decrease; the AVAIL value will be unchanged.
  • B. The USED value will decrease and the REFER value will increase; the AVAIL value will increase.
  • C. The USED value will decrease, the REFER value will decrease; the AVAIL value will increase.
  • D. USED, REFER and the AVAIL value will be unchanged.
To reduce the use at storage space on your server, you want to eliminate duplicate copies of data in
your server's ZFS file systems. How do you specify that pool1/data should not contain duplicate data
blocks on write operations?
  • A. zfs create –o compression=on pool1/data
  • B. zpool create –o deduplication=on pool1 ; zfs create pool1/data
  • C. zpool create –o dedupratio=on pool1 ; zfs create pool1/data
  • D. zfs create –o dedupratio=2 pool1/data
  • E. zfs create –o dedup=on pool1/data
Which option lists default checkpoints for building an image using the Distribution Constructor?
  • A. manifest-valid and ba-init
  • B. ba-arch and grub-setup
  • C. transfer-ips-install and pre-pkg-img-mod
  • D. pkg-img mod and create-usb
Which two statements describe the capabilities of the Distribution Constructor?
  • A. ISO images for use with the Automated Installer (AI) can be created.
  • B. Bootable USB images can be created for SPARC and x86 architectures.
  • C. A single installation server can be used to create ISO imager, for SPARC and x86 architectures.
  • D. Checkpoints are used to pause the build, thereby allowing the running of a script to modify the resulting ISO image.
  • E. A single installation server can be used to create ISO images for Solaris 10 and Solaris 11.0 operating systems.
B, E
Your colleague is administering the companys Automated Install server and is using a custom
manifest. You now plan to replace the default AI manifest with the custom manifest.
Which installadm subcommand must you use to replace the default AI manifest?
  • A. update-service
  • B. update-manifest
  • C. set-service
  • D. create-manifest
  • E. create-service
  • F. set-manifest
