oracle 1z0-632 practice test
PeopleSoft PeopleTools 8.5x Implementation Essentials Exam
Last exam update: Apr 21 ,2025
Identify two types of tables used in the PeopleSoft feature named TableSet Sharing. (Choose two.)
  • A. Cluster tables
  • B. Temporary tables
  • C. Transparent tables
  • D. Transaction tables
  • E. Audit tables
  • F. Control tables
D,F
An end user is accessing your field application for the first time using her smartphone. What will the
end user notice based on the settings shown in this example?
  • A. The end user will not be able to navigate back to pages previously accessed
  • B. The end user will need to navigate to the classic homepage to access this component because it is an activity guide
  • C. To save screen space on the small screen and to send less data to the phone, only the layout outline of the page elements will be visible
  • D. The Notifications button will not appear in the fluid header for smartphones
  • E. The end user will not see a tile on the fluid homepage to tap for accessing for the component
Select the two Application Designer definitions that demonstrate how referential integrity is
maintained in PeopleSoft applications. (Select two.)
C,D
View the following sample search page:
On the Human Capital Management search page, why is the Course Code field limited to accept only
begins with searches, whereas the Description field accepts a wide range of search operators?
  • A. Description is an alternate search key
  • B. The Required check box is selected for the Course Code field on the Edits tab of the Record Field Properties dialog box
  • C. Course is a character (Char) field, while Description is a long character (Long) field
  • D. Disable Advanced Search Options is selected for the Course field on the Use tab of the Record Field Properties dialog box
  • E. Course is a primary key, and primary keys can only run “begins with” searches
Here is a partial list of steps in the component processor flow.
What is the correct order?
  • A. 2, 4, 5, 1, 3, 6
  • B. 2, 1, 4, 3, 6, 5
  • C. 2, 1, 3, 4, 5, 6
  • D. 1, 2, 3, 4, 5, 6
  • E. 6, 2, 1, 4, 3, 5
Which statement is correct about the following PeopleCode statement?
  • A. RO_ROWSET is the superclass of the Rowset class
  • B. Rowset is the superclass of the RO_ROWSET class
  • C. RO_ROWSET is an instance of the Rowset class
  • D. Rowset is a subclass of the RO_ROWSET class
  • E. RO_ROWSET is an application class in the Rowset application package
Which two field types should be places as the last field in the list of fields in a PeopleSoft record
definition? (Select two.)
  • A. Character
  • B. Attachment
  • C. ImageReference
  • D. Prompt
  • E. Image
  • F. LongCharacter
D,E,F
What are the required steps for using a PeopleCode application class? Arrange them in the correct
order.
  • A. 1, 2, 5, 3
  • B. 1, 2, 4, 5, 3
  • C. 2, 1, 4, 3
  • D. 1, 2, 4, 3
  • E. 2, 1, 4, 5, 3
Which three statements are correct? (Choose three.)
  • A. Derived/work fields and variables can be displayed on the page
  • B. Derived/work fields and variables provide temporary storage of calculated values
  • C. Derived/work fields and record fields provide permanent storage of values
  • D. Derived/work fields and record fields can be displayed on the page
  • E. Derived/work fields and record fields can include executable PeopleCode programs
A,D,E
You have been asked to create a new record for student suggestion review, which includes a field for
implemented Flag, which will be a check box on the page. Before creating a new field, you look for an
existing field to reuse.
FLAG, as shown in the exhibit, is a PeopleSoft delivered field. You can use this field if which
statement is true?
  • A. The field only requires adding translate values
  • B. The field only requires modifying it to be a Y/N table
  • C. The field only requires modifying the field format
  • D. The field does not require any modifications
  • E. The field only requires an additional field label
At line number 7 in this record definition, the PSU_ADDRESS_XXX field name represents a ___.
  • A. Subpage
  • B. Compound field
  • C. Subrecord
  • D. Derived/Work record
  • E. Composite field
This SQL definition uses effective-date logic to return the current row from PSXLATITEM.
Which meta-SQL element should be substituted for date so the SQL correctly returns the current row
as of the run date for all supported database platforms?
  • A. %CurretnDateIn
  • B. %CurrentDateOut
  • C. %Date
  • D. %DateTime
  • E. %EffDtCheck
At what occurs level is the Reviewer Details scroll area?
  • A. 1
  • B. 3
  • C. 2
  • D. 4
  • E. 0
Instructors have complained that they do not have access to a newly registered component and
page. The Instructor role that includes the Instructor permission list already exists; both are available
for your use. Select the two correct methods that add access for just this user group. (Choose two.)
  • A. Modify the content reference (CREF) definition in the portal registry and enable the Author Access option
  • B. Re-run the Registration Wizard. Select the option to modify only a permission list, and add the Instructor permission list to this component
  • C. Modify the CREF definition in the portal registry and add the Instructor role
  • D. Modify the Instructor permission list definition and add access to the new component and page
  • E. Modify the CREF definition in the portal registry and add the Instructor permission list
  • F. Modify the CREF definition in the portal registry and enable the Public Access option
B,D
What do you need to do to display the Add a New Value search page as shown in this exhibit?
  • A. Select the Add check box in the Toolbar group box on the Internet tab of the Component Properties dialog box
  • B. Select a Primary Action of New in the Search Page group box on the Internet tab of the Component Properties dialog box
  • C. Select a Default Search Action of Add in the Search Page group box on the Internet tab of the Component Properties dialog box
  • D. Select the Add check box in the Actions group box on the Use tab of the Component Properties dialog box.
  • E. Select a record from the Add search record drop-down list on the Use tab of the Component Properties dialog box
