Oracle Business Process Management Suite 12c Essentials Exam
Last exam update: Feb 11 ,2025
Page 1 out of 6. Viewing questions 1-15 out of 76
Which option is unusable as a start point to initiate a new instance of a process?
Initiator User Task
Call Task
Receive Task
Message Start Event
Which two statements are true about installing BPM Suite in a production environment? (Choose two.)
You must run the Repository Creation Utility (RCU).
The SOA/BPM infrastructure is typically supported by a managed server.
You typically run the SOA/BPM infrastructure on the admin server.
The JDeveloper Installation from a Quick Start default domain installation cannot access the SOA/BPM infrastructure running in a production installation.
The compact installation domain could be used in a production environment.
Which two statements are accurate about how ADF Business Components can be used in a task flow for a human task? (Choose two.)
They can create and insert a new row in a database table.
They can invoke wildcard control flow rules in the task flow.
They can initialize the information displayed on a form when given an ID from the process payload.
They can declaratively map database information back into the process payload.
They can invoke task flow call activities.
B, E
Which two statements are true about BPM Suite product architecture? (Choose two.)
The Process Asset Manager is a container of reusable, shared, implementation assets available to all processes within a BPM project.
Business architecture modeling is supported by a third-party product that Oracle resells as part of the BPM Suite 12c product family.
BPM Suite leverages SOA Suite infrastructure and tooling to support key design-time and run-time features.
case Management is an Oracle add-on product to add adaptive case management support to BPM Suite.
BPM Suite supports BPMN process modeling notation in both BPM Process Composer and BPM Studio.
Which two statements are true about an auto-generated ADF task form for a human task? (Choose two.)
It can be customized by changing the layout and by adding and removing UI components.
It is created in a separate project and in a directory that you select.
You initiate auto-generation from the properties window for the human task activity on your model.
By default, it is automatically deployed when you deploy your BPM project.
Which two objectives can you achieve by using business rules to direct human workflow? (Choose two.)
Load balance tasks among users based upon server utilization.
Redirect the process flow as specified in the BPMN model.
Escalate and reassign a task to the manager of the current assignee.
Skip all subsequent routing and mark a task as complete.
Which two statements are true about business indicators used for process analytics? (Choose two.)
A counter must be associated with a counter mark in order for the counter to be incremented.
Measures specify how process analytics data can be filtered or grouped.
If you do not define any business indicators, no data is captured at a sampling point.
Measurement marks are defined on sequence flows and are visible on the model.
The dimensions you have defined are visible on the process model.
Which statement is true about optimizing performance when using the ITaskQueryService API?
Flex field mappings must be requested as part of the optionalInfo task.
TheIWorkflowContext must be cached by the client.
The default flex field indexes must be used.
Identity propagation must be used.
Which statement is true about how if-then rules are processed during an inferencing session?
Rules are evaluated in the order in which they were added to the ruleset.
A particular rule can be fired only once in an inferencing session.
The effective date set for a rule can take it out of consideration for evaluation.
A priority setting of 1 causes the rule to fire during each inferencing session.
Rules with multiple IF conditions receive higher priority during evaluation.
Which two statements are true about configuring service tasks? (Choose two.)
A service task can be configured to invoke a process or service asynchronously.
Although you call a file adapter as a service from your BPMN diagram, no linkage between your BPMN process and the external reference appears in the SOA Composite Editor.
You can invoke a BPEL process by using a service task.
The implementation of a service task can be either a process call or a service call.
Which two statements are correct about business indicators? (Choose two.)
They can be captured at measurement marks.
Dimensions allow the user to capture numerical values.
All business indicators are captured at sampling points and a subset is captured at measurement marks.
Counters are used for interval start and interval stop measurements.
Explanation: A Measure Business Indicator is used to capture something that can be measured. The BPMN Service Engine automatically stores the data in the dimension business indicators inthe pre-defined and custom sampling points defined for your process.
Which two can be added as members of a static approval group? (Choose two.)
Users
Groups
Application roles
other approval groups
WebLogic administrators
Explanation: Members of a static approval group can be either users or other approval groups. Reference: http://docs.tpu.ru/docs/oracle/en/fmw/11.1.1.6.0/user.1111/e15175/bpmug_ws_admin.htm
Which two case elements can have due dates configured? (Choose two.)
Case
Case data
Events
Milestones
Activities
Which action enables support for virtualization through libOVD?
Update the order of the WebLogic authentication providers to put the LDAP providers first.
Use Enterprise Manager or WLST to add the virtualize=true property to the SOA Common Properties MBean.
Use Enterprise Manager or WLST to add the virtualize=true property to the domain level Identity Store Configuration.
Update the domain directory to include a valid libOVD adapter configuration file under the config/fmwconfig folder.
Which three statements are accurate about BAM 12c alerts? (Choose three.)
Conditions are optional settings for constraining the time period in which the alert is fired.
An action can invoke a web service.
Alerts can be created in either BPM Studio or BPM Process Composer.
You cannot create alerts that launch other alerts.
An event can result when a CQL query receives new data outside a normal range.
A, E
Explanation: Conditions are optional settings for constraining the time period in which the alert is fired. You can select any number and combination of conditions. When you select the eventSelect a CQL Query, you must select a continuous query from the pop-up drop-down list. The alert fires when the query receives new data with values outside of a normal range.
