Oracle WebLogic Server 12c: Advanced Administrator II Exam
Page 1 out of 9. Viewing questions 1-15 out of 125
Examine the illustration: Which best describes the above illustration?
Oracle Service Bus
depicts an Active GridLink Data Source between WebLogic Server and an Oracle Database service that includes two RAC nodes
Oracle ExaLogic
depicts a FAN-disabled Data Source between WebLogic Server and an Oracle Database service that includes two RAC nodes
Oracle Tuxedo
depicts a Multi Data Source between WebLogic Server and an Oracle Database service that includes two RAC nodes
Oracle Data Guard
depicts a Data Source using SCAN between WebLogic Server and an Oracle Database service that includes two RAC nodes
What is the first action to take during a Rolling Update? (Choose the best answer.)
You create a JMS-transacted session if you are using only JMS in your transactions.
Change the Startup Mode to Development; Production Mode is not supported.
You set various levels of control over message acknowledgement.
Remove all managed servers from any cluster and reassign them after the update.
Use message-driven beans if consumers are nondurable.
Do a Force Shutdown of all the servers, including the Administration Server.
Use a JTA user-transactions in a non-transacted JMS session.
Back up your applications, database schema, other application data, and domains.
Stop all Node Managers that support the domain to be updated.
Review this scenario of an application running on a storage-disabled, managed Coherence server that uses a Coherence two-tier near cache: Cache data is already written to the distributed cache. There is a local near cache configured on the application side (storage-disabled node). Application requests the data from Coherence twice. Assuming this is the servers first access of this data from the cache, how many network round trips between Coherence cluster instances take place in total? (Choose the best answer.)
The -redeploy argument is used when executing the weblogic.Deployer command.
The -distribute argument is used when executing the weblogic.Deployer command.
The -distribute argument is used when executing the weblogic.Deployer command and the domain must be in development mode.
The -redeploy argument is used when executing the weblogic.Deployer command and the domain must be in development mode.
I am sending a set of ten JMS messages. I want all of these messages to be sent successfully or none at all. Which JMS Session feature is most suitable for implementing such a scenario? (Choose the best answer.)
Create a new message in the queue.
Transacted Session
Duplicate a message.
Unit of Order
Monitor the content of a message.
Store and Forward
Delete the message from the queue.
Persistent Session
Merge two messages.
Server affinity
F.
Alter the ordering of the messages.
You are designing an application that uses JMS transactions to coordinate a group of messages for production and consumption, treating messages sent or received as an atomic unit. What are two ways you can use transactions in JMS? (Choose two.)
keytool -gencert -alias myCertName -infile myCertName.csr -outfile myCertName.der
keytool -certreq -alias myCertName -file myCertName.csr –keystore myKeyStore.jks
keytool -printcertreq -alias myCertName -file myCertName.csr –keystore myKeyStore.jks
keytool -genkeypair -alias myCertName –dname “CN=MyCert” –keystore myKeyStore.jks
A,D
What is the difference between a WebLogic Diagnostic Framework (WLDF) watch and a notification? (Choose the best answer.)
Allow Post-Migration Script To Run On a Different Machine is selected by default.
A watch compares WLDF instrumentation data to a rule and sends a notification SMS text message.
The default server migration policy is Auto-Migrate Exactly-once Services.
A notification compares WebLogic log data to a rule and notifies a watch when the rule is true.
The participating cluster should include at least one configured server.
A notification compares WLDF instrumentation data to a rule and notifies a watch when the rule is true.
An automatically migrated service will always be hosted on the specified User Preferred Server.
A watch compares WLDF metric data to a rule and triggers a certain notification action.
On a WebLogic Managed Server you administer, you have the following log: You investigate and find a Web Module named MyApp with the following deployment descriptor weblogic.xml: Which two are true? (Choose two.)
Hexadecimal (e.g., 0xCAE987ВA401)
Access to Web Module MyApp now returns an HTTP Error: 503 Service unavailable.
Numeric (e.g., 9018199222001)
The ExecuteThread: 17 is now available because WebLogic Server automatically stops stuck threads.
Floating Point (e.g., 10029920902.10111)
When the WebLogic Managed Server is restarted the Web Module will be in Admin mode.
Doubly dot delimited (e.g., 683871.1122857923566.0)
If another thread is stuck the error number will be <BEA-000338> in the WebLogic log file.
The health status of the Managed Server where the application is deployed is now warning due to the subsystem pooltread.
B,D
You have defined Uniform Distributed Destination (UDD) topics targeted to multiple JMS servers. Which three statements are correct about UDDs? (Choose three.)
UDDs guarantee the order of messages.
UDDs increase the overall availability of JMS.
Weight-based load balancing policy distributes messages evenly to servers with preassigned weights.
JMS destinations do not need to run on each server in a cluster.
You no longer need to create or designate destination members.
B,D,E
You are configuring two-way SSL for a WebLogic Server domain. As a security professional, you realize that even if a client certificate is authentic, it is always possible for a valid certificate to become compromised. Which two options can you configure for WebLogic Server to check if a certificate it receives has been compromised? (Choose two.)
A singleton service must be configured.
Certification Revocation List
A shared file system must be created.
Certificate Revocation Status Protocol
Each migratable server must be assigned a floating IP address.
Online Revocation Status Protocol
Either a database leasing service or a consensus leasing service must be configured.
Online Certificate Status Protocol
A database leasing service must be configured.
A,D
Which three tools allow you to create a Domain Template? (Choose three.)
A new deployment plan will be generated and saved at the indicated location.
JDeveloper
The modification attempt will fail because there is no deployment descriptor included within the application.
pack command
The modification attempt will fail because there is no existing deployment plan associated with the application.
Smart Template Wizard
A new skeleton plan.xml will be generated if a plan folder is detected with the deployed application.
weblogic.Build
Domain Template Builder
F.
WLST
G.
Archive command
B,E,F
G
You are using the administration console to monitor messages in a queue. Which three tasks can be performed while doing this monitoring? (Choose three.)
JMS
JDBC
sample applications
servers
clusters
Merge two messages.
F.
machines
F.
G.
administration username and password
C,D,F
G
A client application asynchronously receives the message sent to a JMS Queue. The client is going to send a response to the sender. Which two JMS Header fields from the original message are used to send the response? (Choose two.)
SRANDBY
JMSResponseMode
ACTIVE
JMSTimeStamp
STUCK
JMSDeliveryMode
RUNNING
JMSCorrelationID
WAITING
JMSReplyTo
F.
ADMIN
G.
FAILED
D,E
G
Which statement is correct for JTA service migration? (Choose the best answer.)
Add an exception handler for the onMessage method in the MDB.
TLOG files should be stored on a remote file system accessible only to the migration target server.
Set the Redelivery Limit for the Queue to zero.
TLOG files should be stored on a shared storage accessible from the migration source and the administration server.
Use container-managed transactions, so that messages are redelivered if unacknowledged.
TLOG files should be stored on the local file system of the migration source server.
Set the MDB instance count to 1 in the deployment descriptor.
TLOG files should be stored on a remote file system accessible only to the migration source server.
TLOG files should be stored on a shared storage accessible from migration source and target servers.
You have been tasked with deploying and targeting a new application to every server in a WebLogic cluster. Some servers are running on machines that have access to a common shared file system, while other servers do not have that same access. Currently, the default deployment staging mode for all servers in the cluster is set to STAGE however, you wish to avoid having the AdminServer automatically copy the application to the servers (in that cluster) with shared file system access. Which two approaches would satisfy the above requirement? (Choose two.)
The machines that host the cluster should have similar processing power, disk space, and memory.
Change the default deployment staging mode for all servers to EXTERNAL_STAGE, and then copy the application to all servers.
The cluster should include at least one configurable server.
Change the default deployment staging mode for the servers with access to the shared file system to NO_STAGE, then copy the application to the shared file system.
The cluster should use unicast communication.
Change the staging mode of the application to EXTERNAL_STAGE when you are deploying it to the cluster.
All servers in the cluster should be assigned to the same WebLogic machine.
Leave the default deployment staging mode for all servers as STAGE, but copy the application to the shared file system prior to deployment.
A,C
Your application includes a message driven bean (MDB) that is listening to messages on a JMS Queue. You need to ensure that every message is processed exactly once by the MDB. Which configuration allows you to achieve this requirement? (Choose the best answer.)
Configuration changes can be made during the Rolling Update process.
A major upgrade, for example 11g to 12c, can be accomplished with a Rolling Update.
The machines can be upgraded in any order.
The machine hosting the Administration Server must be upgraded first.
Avoid configuration changes until all the servers in the domain have been upgraded.
