oracle 1z0-1082-21 practice test
Oracle Profitability and Cost Management 2021 Implementation Essentials Exam
Which two statements are true about allocation offset for allocation rules?
  • A. Offsets are written to the Allocation Offset member of the Balance dimension, in combination with the other dimension members defined for the offset.
  • B. Defining an allocation offset Is optional.
  • C. The offset location defines the member to hold any unallocated data from the source.
  • D. By default, offsets are written to the source.
After running a calculation, you are evaluating the results In the Rule Balancing screen. What can you
do to Investigate the data In more detail?
  • A. Click on either Allocation in or Allocation Out to open an Allocation Trace.
  • B. Click on a value to drill down to more detail in the Rule Balancing screen.
  • C. Click on a rule number to open a report showing the entire allocation flow.
  • D. Click on a value to open a context sensitive query in Smart View.
You update the name of a member that Is used In a number of allocation rules.
After deploying the changes to the database, what step can you take next to update your rules?
  • A. The system automatically propagates the name change to your allocation rules; no additional step is necessary.
  • B. Use the Find and Replace tool In the Manage Rules screen to replace the member In all rules that use It.
  • C. On the Mass Edit tab of the Designer screen, create and run a job to replace the member in all rules that use it.
  • D. Use the ReplaceMember command In EPM Automate to replace the member In all rules that use It.
Which three are valid ways to create Profitability and Cost Management applications?
  • A. Import a backup snapshot from another instance of Profitability and Cost Management,
  • B. Create a custom application with dimensions from Hal files.
  • C. Create a custom application from an Essbase outline file.
  • D. Create a custom application with no dimensions, then create and load dimensions in Data Management.
  • E. Migrate an exported on-premises Profitability and Cost Management application using a migration template file.
A, C, E
Which three are valid statements about Locations In Data Management?
  • A. A location can be assigned to more than one data load rules.
  • B. A location can be assigned to more than one Import format.
  • C. You can create duplicate locations with the same source system and application combination.
  • D. Different locations can use the same import format.
  • E. A location may have more than one source system.
A, C, D
Which two statements are true about managing Points of View (POVs)?
  • A. You can archive POVs, but you cannot delete them.
  • B. A POVs status is automatically changed to Calculated when you calculate the POV.
  • C. When you add a new POV, the status Is automatically set to Draft.
  • D. Global rules and rule sets are not associated with a specific POV.
  • E. All POVs are data POVs, even If the data set Is empty.
E 2 votes
Which Is NOT a valid Point of View (POV) state?
  • A. Archived
  • B. Final
  • C. Published
  • D. Draft
Which two statements are TRUE about cloning snapshots?
  • A. You cannot clone a snapshot to a target In a different Identity Domain from the source.
  • B. You can select any snapshot from the source environment to clone to the target environment.
  • C. After cloning, the daily maintenance start time of the target environment Is reset to that of the source environment.
  • D. The cloning process deletes any existing application and uploaded files from the target environment.
You are creating a rule set for allocation rules. On the description tab, you select Use Global Context.
Which two statements are true?
  • A. You can override the global context dimension selections at the rule set level.
  • B. When you select Use Rule Set Context for a rule In this rule set, the dimension-member combinations defined In the Global Context section are also applied.
  • C. At the rule level, the Rule Context tab is where you can edit any default contexts applied to the rule.
  • D. On the Context tab for the rule set, you define default members for use In all rules added to the rule set.
Which three are valid statements about batch processing in Data Management?
  • A. Batches can be executed from EPM Automate.
  • B. Service Administrators can configure security to limit which batches users can run.
  • C. Batch processing combines one or more data load rules In a batch so you can run multiple data load rules In one step.
  • D. Batch processing combines one or more dimension builds In a batch so you can run multiple dimension builds in one step.
  • E. Batch processing does not support parallel loading of data files.
A, B, D
Which two are valid statements about Profitability and Cost Management application requirements?
  • A. Changes to Profitability and Cost Management dimensions must be deployed to the underlying Essbase database before running allocations.
  • B. You must have access to a separate instance of Oracle Analytics Cloud (Essbase) to use as the underlying data storage for Profitability and Cost Management.
  • C. You can configure the underlying Essbase database as either a Block Storage (BSO) type or Aggregate Storage (ASO) type.
  • D. Applications must have a Point of View with Year, Period, and Scenario dimensions.
  • E. An EPM Cloud service instance can support only one Profitability and Cost Management application at a time.
E 2 votes
Which Is NOT Included In the Profitability and Cost Management analytics tools?
  • A. Trace Allocations
  • B. Analysis Views
  • C. Key Performance Indicators (KPIs)
  • D. Sculler Analysis Graph
  • E. Rule Update Analysis
Which three are valid functions of logic accounts In Data Management?
  • A. Logic accounts allow the mapping of a source account based on its value (conditional mapping).
  • B. Logic accounts can perform arithmetic operations on source values (arithmetic mapping).
  • C. Logic accounts determine how the source fields are stored In the Data Management staging tables (storing mapping).
  • D. Simple logic groups enable you to derive logic items front any combination of dimensions (derived mapping).
  • E. Logic accounts allow the mapping of one source account to multiple target accounts (statistical mapping).
B, C, E
E 2 votes
Assume the computer hardware supports parallel calculation. Given these two rule sets, in what
order will the rules be calculated?
  • A. Rule 1, Rule A, and Rule 5 will run In parallel; then Rule 2, Rule, 3, and Rule 6 will run in parallel (two separate calculation steps).
  • B. Rule 1; then Rule 2 and Rule 3 will run in parallel; then Rule 4 and Rule 5 will run in parallel; then Rule 6 (four separate calculation steps).
  • C. Rule 1, Rule A, and Rule 5 will run in parallel while Rule 2, Rule 3, and Rule 6 also run in parallel (one calculation step).
  • D. Rule 1; then Rule 4 and Rule 5 will run in parallel; then Rule 2 and Rule 3 will run in parallel; then Rule 6 (four separate calculation steps).
For which two of these purposes can you use model views?
  • A. To create analysis views for specific slices of data
  • B. To assign data grants to specific slices of data
  • C. To filter the results when tracing allocations or performing rule balancing
  • D. When mass editing rules, to limit the edits to a subset of the data
  • E. When copying POVs, to limit the copy to a subset of the data
A, E
