oracle 1z0-1079-21 practice test
Oracle SCM Transportation and Global Trade Management Cloud 2021 Implementation Essentials Exam
How would you create an association in OTM if you want to associate a Match Rule to a specific
Service Provider (carrier)?
  • A. Create the Rule, then assign the Service Provider to the Rule.
  • B. Create the Rule, then assign the Rule to the Service Provider.
  • C. Create the Rule, assign the Rule to an appropriate Rule Profile, then assign the Rule Profile to the Service Provider.
  • D. Create the Rule, assign the Rule to an appropriate Rule Profile, then assign the Service Provider to the Rule Profile.
mpc44
1 year ago
Service providers need match rule profile assignement
You are writing an order release agent and need to listen for an order modification event triggered by
an integration update to the order release.
What is the impact to the agent process if you set the before persist flag on the ORDER MODIFIED
event?
  • A. Shipment Total Distance Traveled
  • A. OTM will perform the agent actions but will not persist any changes to the object.
  • B. Shipment Total Weight
  • B. OTM stages the new data, will perform the agent actions, will not allow you to use certain actions.
  • C. Shipment Total Transit Time
  • C. OTM will not persist the new data but will perform the agent actions as long as they do not require persisting the new data.
  • D. Shipment
  • D. OTM stages the new data but will not perform the agent actions if the data is not persisted properly.
  • E. Shipment Total Pieces of Equipment
  • E. OTM will persist the new data immediately after the agent is triggered and then perform the agent actions.
What must you do in order to export data from the CONTACT table, so that the data only includes
contacts with email addresses ending with @oracle.com?
  • A. The rules cannot be changed once assigned to a service provider
  • A. The CSV utility is useful for managing large amounts of data, but it is not capable of filtering data during the export process.
  • B. The Autopay check box should be selected for the rules to apply
  • B. Export the data first, and then use software such as MS Excel, MS Access, or direct SQL to filter the data.
  • C. One can assign a match rule profile and an approval rule profile to a service provider
  • C. Use the “Where” clause on the CSV Export screen to specify the “@oracle.com” qualifier.
  • D. Each service provider can have only one match rule profile assigned
  • D. Create a CSVUTIL file that specifies the “@oracle.com” qualifier.
Select the three business objects that can be managed using the Fleet Management module.
(Choose three.)
  • A. AGENT, CUSTOM_EVENT, SAVED_CONDITTON, SAVED QUERY
  • A. Driver payroll
  • B. AGENT, EVENT, SAVED_CONDITION, SAVED QUERY
  • B. Fleet power units
  • C. AGENT, CUSTOM_EVENT, SAVED_CONDITION
  • C. Fleet equipment
  • D. AGENT, AGENT_EVENT, SAVED_CONDITION_QUERY
  • D. Driver time off, sick time, vacations, etc.
  • E. AGENT, AGENT_EVENT, SAVED_CONDITTON, SAVED QUERY
  • E. Driver work hours
ACD
Which three statements are true when setting up Match Rules for Freight Payment in OTM? (Choose
three.)
  • A. Assign License
  • A. You need to specify at least one shipment reference number qualifier to match to.
  • B. Determine License
  • B. The match rule will apply to all invoices, unless only certain service providers are specified on the match rule.
  • C. Reevaluate License
  • C. The matching rule could be different for different service providers.
  • D. Assign License Show Options
  • D. You could specify several shipment reference values to match to.
  • E. BM or Bill Of Lading is a mandatory shipment reference number qualifier to match to.
ACE
Which four of the following components make up a Compliance Rule in Global Trade Management
(GTM)? (Choose four.)
  • A. Active
  • A. Regime
  • B. Booked
  • B. Control Type
  • C. BOL
  • C. Region
  • D. Accepted
  • D. Control Code
  • E. Pickup Notification
  • E. Commerce Control List
ABCD
Assume that you have made changes to the Default Parameter Set. Which statement is true?
  • A. EDI documents
  • A. Regardless of your user role, you won't be able to save the changes within the Default Parameter Set without renaming it first.
  • B. Static Data
  • B. In order to reset all the changed settings back to their original settings, select “Actions”, then “Utilities”, and then “Set Defaults” from the drop-down menu.
  • C. Transactional data
  • C. In order to reset all the changed settings back to their original settings, you should review them on the screen and be able to tell which ones have been changed, and what the default settings were.
  • D. Shipment Status Updates
  • D. In order to reset all the changed settings back to their original settings, you should delete the Parameter Set and recreate it using the Default as your template.
  • E. Rates
Youve executed a CSV upload in which you have modified some existing records, and created some
new records. There were no errors during the upload. However, OTM is still retrieving only the old
data, not the new data that was just uploaded.
Select the action that you can take to address this.
  • A. Date Format
  • A. You must reboot the database server in order to commit the changes.
  • B. Language
  • B. Rerun the upload, this time making sure that you specify the “dd” command.
  • C. Business Monitor
  • C. You should clear the OTM cache.
  • D. Menu
  • D. Rerun the upload, this time making sure that you specify the “ii” command.
  • E. User Role
  • E. Rerun the upload, this time making sure that you specify the “uu” command.
If you have just installed OTM, which domain would not be created by default?
  • A. Such a conflict cannot exist in OTM
  • A. MASTER
  • B. The Rate Record will take priority over the Rate Offering configuration
  • B. SERVPROV
  • C. During planning, the user will have the option of indicating if OTM should prioritize either the Rate Offering or the Rate Record setting
  • C. GUEST
  • D. The Rate Offering will take priority over the Rate Record configuration
  • D. BLUEPRINT
  • E. OTM’s planning engine will run the solver for both settings, but only consider the least cost result
  • E. STAGE
Select the three correct statements regarding Freight Settlement in OTM. (Choose three.)
  • A. Items can be sent from an ERP system, such as Oracle ERP Cloud, to GTM
  • A. Invoice checks may be printed out of OTM.
  • B. Items can be uploaded by CSV in GTM
  • B. Rules for matching, approval, and allocation are the cornerstones of automation in Freight Settlement.
  • C. Items can be uploaded by the Product Classification Template in GTM
  • C. Freight Invoices may be created within OTM or interfaced from an external system.
  • D. Items can be downloaded from the External Content Provider
  • D. Invoices in OTM must be tied to a shipment.
  • E. Items can be manually created in the GTM UI
  • E. Freight Settlement in OTM may be used to pay invoices to carriers as well as bill customers for freight.
ACE
Given the information:
Which two options are correct for Service Preference configuration? (Choose two.)
  • A. Agents can be configured to run multiple times on a time-based schedule
  • A. Exclude Words is used to specify words to exclude when ONLY “Dice” Match Engine is used.
  • B. Agents can send alerts when a condition is occurred, and they can also create or change data objects
  • B. At the most sixty-four words can be specified in Exclude Words.
  • C. Agents can send alerts when a condition is occurred, but they cannot create or change data objects
  • C. It is not mandatory to specify Agency Code.
  • D. Agents “listen” for a condition to occur
  • D. If the Data Version ID is not specified, then the system will throw an error during screening that Data Version ID needs to be specified.
  • E. If the Data Version ID is not specified and if there is a Restricted Parties List with a Data Version with the Current flag set, it will be used for screening.
BE
To import Rates in OTM, which are four key components that you must configure? (Choose four.)
  • A. Finders (Search pages)
  • A. Rate Service
  • B. Reports
  • B. Lanes
  • C. Automation Agents
  • C. Rate Offering
  • D. Business Monitors
  • D. Accessorial
  • E. Itinerary
  • F. Rate Quality
  • G. Rate Record
ACDG
G 1 votes
G
Your customer has US and Germany orders.
How would you setup a User role with read/write access for US orders, and only read access for
German orders?
  • A. Voyage
  • A. Assign multiple User Roles while creating User.
  • B. Static
  • B. Access can be controlled via VPD profile along with external Predicates.
  • C. Dynamic
  • C. Access can be controlled via Access Control List and assign to User Role.
  • D. Multi-Modal
  • D. Assign multiple User Role grants in User Role.
  • E. OTM allows the user to configure custom Trip types based on need
After creating a report, which step must occur in order to register the report for execution within
Oracle Transportation Management?
  • A. Invoices from OTM must be tied to a shipment
  • A. Create a new Data Source pointing to the OTM database.
  • B. Freight Invoices may be created within OTM or interfaced from an external system
  • B. Select the Report System and specify the Report Path.
  • C. Freight Settlement in OTM may be used to pay invoices to carriers as well as bill customers for freight
  • C. Create a new Data Source pointing to the BI Publisher database.
  • D. Invoice checks may be printed out of OTM
  • D. Make a directory "BIPCatalogUtil" under [BI Publisher Home]/
  • E. Rules for matching, approval, and allocation are the cornerstones of automation in Freight Settlement
Which output option from the below is available for exporting data using the CSV Export function?
  • A. Set up a License Code that defines whether a license is incremented or decremented for the Trade Transaction
  • A. browser window
  • B. Define a constraint set with grouping criteria that identifies how to combine Trade Transactions into a Declaration
  • B. a file on your database server
  • C. Define a unique value set for each Transaction Line set of parameter combinations
  • C. MS Excel
  • D. Create aggregation criteria that consolidate Transaction Lines, based on parameters such as tariff code or country of origin, into fewer lines on the final Declaration
  • D. text editor programs such as Notepad
  • E. Set up a data configuration that defines the data required to be copied from the Transaction onto the Declaration
