The audit selection rule has not been assigned to the business unit
You have evaluated the use of Oracle Maps Cloud service with Expenses for mileage calculation. The
decision is to use this feature.
How do you enable the feature?
Create a mileage policy, optionally include a commute deduction rule, and then assign the mileage
policy to an expense type to activate the policy.
https://docs.oracle.com/en/cloud/saas/financials/20b/faiex/implementing-expenses.pdf
Your client is concerned that all expense reports are getting automatically approved by the expenses
system despite the setup of an Audit Selection Rule.
What is the reason for this?
Assign audit rules to business units.
https://docs.oracle.com/en/cloud/saas/financials/20b/faiex/expense-policies-and-rules.html#FAIEX654018
Which three options are available to filter data when you submit the Prepare Payables to Ledger
Reconciliation report? (Choose three.)
A, C, D
Typically General Ledger users are secured by data access sets. Data access sets use primary
balancing segment values to secure access to ledgers, ledger sets, and portions of ledgers. Payables
users
are
secured
by business units.
For the Payables to General Ledger Reconciliation report:
General Ledger users can see general ledger data for the balancing segment values in their data
access set. General Ledger users can also see the Payables or Oracle Fusion Subledger Accounting
data
for
all
business units linked to the ledger.
Payables users can see the Payables and Subledger Accounting data for business units in their
security definition. Payables users can also see general ledger data for all balancing segment values
in the ledger.
https://docs.oracle.com/en/cloud/saas/financials/20b/ocuar/oracle-fusion-payables-reports.html#OCUAR444681
In the implementation project, there is a requirement to add new transactional attributes to the
Expense Approver Report workflow notification.
Which two Business Intelligence catalog objects should you copy (or customize) and edit? (Choose
C, E
Style Template: Provides styles such as the type of lines and fonts to use in tables, or the font type,
size, and color to use for headings
Report: Contains a layout template that determines:
Which attributes appear in the notification, from the data model used for the report
What the notification looks like, leveraging components from the subtemplate and styles from the
style template used for the report
https://docs.oracle.com/en/cloud/saas/financials/20b/faiex/expenses-configuration.html#FAIEX2657210
You are testing the Payables to General Ledger Reconciliation report at the ledger level for your UK
Ledger, you have run and selected the extract for the report but the request returned the message no
data to display.
A company has a requirement to default the disbursement bank account when submitting a Payment
Process Request.
Which two actions will accomplish this? (Choose two.)
A Payables supervisor wants to apply a prepayment to an invoice.
Which combination of invoice and payment currencies allow the application of a prepayment to an
invoice?
Standard Invoice: Invoice Currency USD, Payment Currency GBP
Prepayment: Invoice Currency USD, Payment Currency AUD
Standard Invoice: Invoice Currency USD, Payment Currency USD
Prepayment: Invoice Currency CAD, Payment Currency CAD
Standard Invoice: Invoice Currency CAD, Payment Currency GBP
Standard Invoice: Invoice Currency USD, Payment Currency CAD
You can pay a prepayment in a currency that's different from the invoice currency. To apply that
prepayment to an invoice, the invoice must have the same invoice currency as the invoice currency of
the prepayment.
https://docs.oracle.com/en/cloud/saas/financials/21a/fappp/invoices.html#FAPPP421516
Which data is visible to a Payables user in the Payables to General Ledger Reconciliation report?
Payables users can also see general ledger data for all balancing segment values in the ledger.
Which two are true for Payables Payment Terms? (Choose two.)
Assigning a reference data set to a business unit: When you define a business unit, assign the
business unit a reference data set for thePayables Payment Termsreference group.
Before you define common options for Payables and Procurement, you must assign
theImmediatepayment term to the reference data set for the business unit.
https://docs.oracle.com/en/cloud/saas/financials/20b/faipp/payables-configuration.html#FAIPP772430
A company is centralizing their payment processing using the service provider model.
Which reporting level has to be used to run the Prepare Payables to General Ledger Reconciliation
report?
Business unit if you implemented centralized payment processing using theservice provider model.
https://docs.oracle.com/en/cloud/saas/financials/20b/fappp/accounts-payable-balances.html#FAPPP444518
You have created an approval rule as follows:
Rule 1: If the invoice amount > $1000, route it to User 1.
Rule 2: If the invoice amount < $1000, auto approve it.
Now, the user creates an invoice for $1000 and routes it for approval.
What will happen?
A company has three legal entities each with a corresponding business unit all within the same
country. All organizations buy and sell the same products. You are configuring the tax setup.
What is the minimum number of Tax Regimes you need to configure for this company?
You must set up a separate tax registration to represent each distinct registration requirement for a
first party legal reporting unit.
https://docs.oracle.com/cd/E25178_01/fusionapps.1111/e20375/F527690AN1AA76.htm
The Government has introduced a new reduced tax recovery rate for certain services. You need to
amend the configuration for your current tax regime to reflect this change.
Which three setups will you need to complete? (Choose three.)
B, D, F
Explanation: Set up details for the taxes of a tax regime. Each separate tax in a tax regime includes
records that are used to calculate and report on the tax, including:
Tax statuses
Tax rates
Tax rules
https://docs.oracle.com/en/cloud/saas/financials/20b/faitx/tax-configuration.html#FAITX1843284
During an expense audit the auditor marks an expense item that is missing a receipt to be Short Paid.
They choose to complete the audit and warn the user.
Given that the Expense Report Audit Approval is set to After Manager Approval, what two are valid
results of the auditor action? (Choose two.)
New expense report containing disallowed expense items is immediately created.
Expense report isn't eligible for expense reimbursement.
https://docs.oracle.com/en/cloud/saas/financials/20b/fawde/expense-report-audit.html#FAWDE1119039
A Payables user creates a manual invoice and a Withholding Tax Classification Code defaults on the
invoice line when the invoice is saved.
Where does this Withholding Tax Classification Code default from?
Set withholding tax options on the Manage Tax Reporting and Withholding Tax Options page and on
the supplier setup.
https://docs.oracle.com/en/cloud/saas/financials/20b/faipp/payables-tax-and-withholding.html#FAIPP206035
For supplier sites that use withholding tax, the withholding tax classification that you define at the supplier site assignment level is used to populate the default tax classification on the invoice.
Set Enable Oracle Maps to yes in the expenses system options.
