Oracle Financials Cloud: General Ledger 2020 Implementation Essentials
Page 1 out of 7. Viewing questions 1-15 out of 105
You want to process multiple allocations at the same time. What feature do you use?
RuleSets
Formulas
General Ledger journal entries
Point of View (POV)
None
One, because they can all share the same chart of accounts
Three, because each requires a different currency
Two, because the US and Canada can share the same ledger because they are in North America
Four, because the UK has statutory requirements and you will need a separate ledger for statutory reporting
You are implementing a multipillar implementation of both HCM Cloud and ERP Cloud. You are implementing ERP first followed by HCM Cloud. You want to ensure your ledgers and chart of accounts are correctly defined. What should you do? (Choose three)
Deploy your chart of accounts
Use HCM’s Enterprise Structure Configurator (ESC) first
Create your chart of accounts in the following order: value sets, COA structure, and instance before assigning values to the value sets
Use file-based spreadsheet loaders using UCM to mass load and maintain chart of accounts segment values and hierarchies
Use the Rapid Implementation spreadsheet when creating your enterprise structure
A B E
Which two statements are true regarding the Intercompany Reconciliation Report? (Choose two.)
You can only drill down to the general ledger journal and then from there to the subledger journal entry.
This report can be run using an additional currency and conversion rate that converts all amounts into a common currency for comparison.
This report displays only the reconciled transactions. You need to further process automatic reconciliation to reconcile the unreconciled transactions.
This report includes Ledger balancing lines generated when the primary balancing segment value (BSV) is in balance, but either the second or third BSVs are not.
This report displays the intercompany receivables and intercompany payables balances in summary for a period.
B E
Your new accountants have been making mistakes in reconciling accounts assigned to them. Your account balances have either spiked or dropped 30-40% every period due to human error. This causes delays in reconciliation. What feature can you use to be proactively notified of account anomalies in a more timely manner?
Account Monitor
Financial Reports with Embedded charts
Smart View
Account Inspector and its charts
You set up a secondary ledger using the Manage Secondary Ledger task and selected a data conversion level of subledger. Which two actions should you now perform? (Choose two.)
Ensure that the Accounting Calendar and Currency are the same as the Primary Ledger
Define Journal Conversion Rules that include subledgers in order to transfer subledger transactions
Define Journal Conversion Rules that exclude subledgers
Assign a Subledger Accounting Method to the secondary ledger
Define Supporting References with balances
B D
You are defining an income statement report. You want to allow viewers of the report to be able to drill down from report balances to the underlying transactions. What so you need to enable?
Drill Through in Grid Properties
Nothing. All report balances are drillable in all FR Studio reports
Allow Expansion
Report Functions
You just submitted the Accounting Configuration. What two things must happen before you can enter journals? (Choose two.)
You must re-deploy the chart of accounts
A Data Access Set with full read/write access to the ledger is automatically created
You must define a Data Access Set to obtain full read/write access to ledgers in the Accounting Configuration
You must assign the job role and data security context to each user
B D
Your customer uses Financials Cloud, Projects, Inventory and Procurement. Which two statements are true regarding intercompany accounting for these products? (Choose two.)
Each product has its own Intercompany Accounting feature that needs to be set up separately
Within Financials Cloud, Intercompany Balancing Rules are used to balance both cross-ledger intercompany transactions and single-ledger Intercompany journals
Intercompany Balancing Rules are defined centrally and applied across Financials and Project Portfolio Management
They need to license a separate stand-alone Intercompany product that acts as the Intercompany Accounting Hub
B C
The general accountant is trying to update the cost center for the Default Suspense Account in the Ledger Options to match the cost center for the Rounding Account. The rounding account is showing as 01-110-7699-00; however, 110 is not appearing in the List of Values for the accountant to select in the Suspense Account. What is the reason for this?
The general accountant does not have the Financials Application administrator role assigned and, therefore, has view- only privileges on this page
The general accountant has a segment value security rule assigned which restricts access to that cost center
There is a primary balancing segment attached to the legal entity of the primary ledger
A cross validation rule is in place to prevent the resulting combination from being created
You want to achieve multi-step cascading allocations, which feature do you use?
RuleSets
Formulas
Point of View (POV)
When creating financial reports which two tools use data from the General Ledger Balances Cube? (Choose two).
Financial Reporting Studio
Smart View
Oracle Financial Statement Generator
Financial Reporting Center
A D
Explanation: D18912E1457D5D1DDCBD40AB3BF70D5D
Identify three roles that get access to the reports in the Fusion Accounting Hub Reporting Cloud Service (FAHRCS). (Choose three.)
Controller
General Accountant
General Accountant Manager
Business Intelligence Administrator (BI Admin)
Financial Analyst
C D E
In Financial Cloud, which three reporting tools can be used to access General Ledger balances? (Choose three.)
Application Composer
Oracle Enterprise Repository
Oracle Transactions Business Intelligence
Smart View
C D E
You have exported data from your budgeting application into a .csv file. What should you use to load that data into General Ledger?
The budget journal spreadsheet
Enterprise Resource Budget Integrator
File Based Data Import
Application Developer Framework Desktop Integrator
