Juniper jn0-211 practice test
cloud, associate
Last exam update: Nov 19 ,2026
Page 1 out of 7. Viewing questions 1-10 out of 65
You are asked to reduce traffic on an MPLS VPN by automatically moving the traffic to an Internet circuit as long as it satisfies the SLA requirements.
In this scenario, what would you use to accomplish this task?
  • A. Contrail Cloud
  • B. Contrail SD-WAN
  • C. AppFormix
  • D. NorthStar
Which Juniper product provides insight into the underlay and overlay network at the same time?
  • A. Juniper Extension Toolkit
  • B. Security Director
  • C. AppFormix
  • D. Edge Services Director
According to Juniper Networks, what is the recommended external routing protocol for the underlay network?
  • A. OSPF
  • B. BGP
  • C. EGP
  • D. IS-IS
You need to control and steer application traffic while maintaining an end-to-end view of the WAN and LAN.
Which Juniper cloud product will satisfy the requirements in this scenario?
  • A. Contrail Cloud
  • B. Contrail Service Orchestration
  • C. Sky Enterprise
  • D. Sky ATP
Devices in your data center have become unwilling participants of botnet attacks.
In this scenario, which security technology should you use to stop this behavior?
  • A. Sky ATP C&C threat protection
  • B. Sky ATP GeoIP threat protection
  • C. IPsec
  • D. Policy Enforcer
Which two statements are correct about the NFV framework? (Choose two.)
  • A. The NFV framework is defined by ANSI.
  • B. A spine and leaf implementation is an example of the NFV framework.
  • C. The NFV framework enables horizontally scalable deployments of services.
  • D. The NFV framework is defined by ETSI.
cd
What are two reasons to use a vMX over a physical MX Series device in your deployment? (Choose two.)
  • A. A vMX has a lower barrier of entry.
  • B. A vMX accelerates adding new services.
  • C. A vMX increases analytic capabilities.
  • D. A vMX provides more routing features.
ab
Which two statements describe cloud CPE? (Choose two.)
  • A. Cloud CPE eliminates the need for investing in expensive hardware.
  • B. Cloud CPE allows multivendor, open support of software-based functions.
  • C. Cloud CPE requires heavy investment in vendor-specific hardware.
  • D. Cloud CPE encourages administrators to use all-in-one appliances.
ad
Which Juniper product is used to remotely provision the NFX250 platform for Network Functions Virtualization?
  • A. Junos Space Security Director
  • B. Virtual Route Reflector
  • C. Contrail Services Orchestration
  • D. Contrail Security
Which Cloud CPE component manages the end-to-end path from the CPE to the central office or to another CPE?
  • A. virtual network functions
  • B. physical telco cloud infrastructure
  • C. service orchestration
  • D. infrastructure orchestration
