Huawei h35-211-v2-5 practice test
HCIP-Access V2.5
Last exam update: Nov 20 ,2026
The total downstream bandwidth of the 10G EPON PONI port is the sum of the EPON downstream
bandwidth and the 10G EPON downstream bandwidth.
(Radio) 10G GPON system downlink wavelength is
  • A. 1310nm
  • B. 1577nm
  • C. 1270mm
  • D. 1490nm
The maximum spectroscopic ratio supported by 10G GPON is (Radio) ?
  • A. 1:64
  • B. 1:256 :
  • C. 1 128 :
  • D. 1 32
In the evolution of EPON to 10 G EPON, a smooth transition is achieved at the local level by adding
WDM WDM modules, and ODNs coexist
The complete SIP message interaction process will contain multiple request and response messages,
and the sIP message header field can be used to describe what the specific solution corresponding to
the current response message is
  • A. Csea
  • B. CaLL-ID
  • C. First line
  • D. Message body
Under the H.248 protocol, if the signaling IP and media IP are both 10. 1
100/8, voice gateway
is 10. 1
1. When configuring voIP service, the following command is incorrect
  • A. Using the command ip address media10 in voip mode. 1 10010 1 Configure the media IP
  • B. Use the reset coldstart command under Voice Interface to make the interface property configuration take effect
  • C. Use the if-h248 attributei command to configure interface properties under the voice interface . . . . .
  • D. Using the command ip address signaling10 in voip mode. 1 10010 1 Configure the signaling IP
(Radio) When the invitation message sent by user A reaches user B after passing through server C, D,
E, the message received by user B is VI
  • A. C->D->E
  • B. E->C->D
  • C. E->D->C
  • D. C-E->D
The establishment, maintenance and dismantling of the word path between the SIP user and the
server are done through the interaction of the --series of messages, so that every information
contained in the SIP text has a --nature, There is no phenomenon in which a single information value
appears multiple times.
  • A. wrong
  • B. Right
Max-Forwards fields can be used in S1P messages to solve loop problems and avoid endless packet
forwarding.
  • A. wrong
  • B. Right
(Radio) Regarding multicast, the following description is incorrect
  • A. Add Lgmp user under BTV, and by default, multicast users can watch 8 programs.
  • B. The user-issued Report is captured in the single board logic and sent to the single board CPU
  • C. Device-based global configurations of Layer 2 groups refer to common parameters of protocols ( IGMP Proxy, GMP Snoop) to all
  • D. When the igmp match mode disables, you need to configure the multicast program group
(Radio) follow the multicast IP address 227. The correct multicast MAC address corresponding to
120.1.32 is
  • A. 01-00-5e-78-01-32
  • B. 01-00-5e-14-01-20
  • C. 01-00-5e-78-01-20
  • D. 01-00-5e-14-01-32
Under IGMP snooping, there are two users on demand under the OLT- the same program, and the olt
sends two join messages to the multicast router
  • A. wrong
  • B. Right
Multicast technology effectively solves the problem of single-point transmission and multipoint
reception, and realizes efficient data transmission from midpoint to multipoint in IP network.
  • A. wrong
  • B. Right
(Radio) When configuring multicast services on MA5600T/MA5680T, the programs of multicast
VLANs are statically configured, and which of the following options must be configured, otherwise
the multicast programs may not be able to be watched
  • A. igmp profile
  • B. igmp program
  • C. igmp priority
  • D. igmp preview
The Class D multicast address range is from 224. 0
0 to 238. 255
255
255
