Huawei h35-210 practice test
HCIA-Access V2.0 Exam
Page 1 out of 22. Viewing questions 1-15 out of 329
(multiple) Which of the following are the methods and ideas for XDSL dialup abnormal fault location?
  • A. Check the MODEM ATM package format
  • B. Confirm that the MODEM configuration is correct.
  • C. Query the traffic of the xDSL port to determine whether there is normal traffic between the terminal and the terminal.
  • D. Confirm whether the gateway can be pinged from the client.
A B C D
(single) What is the difference between alarm masking and alarm suppression?
  • A. When the alarm masking function is configured, the NE still reports the alarm, but the network management system does not receive the alarm. When the alarm suppression is set, the NE does not report the alarm.
  • B. When the alarm masking function is set, the NE does not report the alarm. When the alarm suppression is set, the NE still reports the alarm, but the network management system does not receive the alarm.
  • C. When the alarm mask function is set, the network element does any processing.
  • D. There is no difference
(multiple) UA2000 alarms are based on whether they are acknowledged and cleared. What are the
alarm statuses?
  • A. Unconfirmed not cleared
  • B. confirmed not cleared
  • C. Unconfirmed cleared
  • D. Confirmed cleared
A B C D
(multiple) What are the levels of the U2000 alarm level?
  • A. fatal
  • B. Emergency
  • C. Important
  • D. Minor
B C D
(multiple) command. What are the correct meanings of the three points in ./.profile?
  • A. The first point. Indicates execution, with sh
  • B. The second point. Connected to the following /, / indicates the current directory
  • C. Third point. Connected to the previous /, indicating the root directory
  • D. The third point. Before the profile, the .profile is a file name, indicating hidden files.
A B D
(single) In the Solaris 10 operating system, when only ordinary users can ftp to the network
management server, which file should be modified so that the root user can also remotely ftp to the
server?
  • A. /etc/ftpusers
  • B. /etc/services
  • C. /etc/system
  • D. /etc/defaultrouter
(single) Which of the following isql login database commands is correct?
  • A. isql -Usa_password -Ssa -PN2000DBServer
  • B. isql -Usa -Ssa_password -SN2000DBServer
  • C. isql -Usa -PN2000DBServer -Ssa_password
  • D. isql -Usa -Psa_password -SN2000DBServer
(single) Which of the following commands is used to shut down the sybase primary server?
  • A. shutdown SYS_MAIN
  • B. shutdown SYS
  • D. Shutdown
(multiple) What are the actual line rates of ADSL services affected?
  • A. Line length
  • B. Wire diameter
  • C. Interference
  • D. Wiring situation
A B C D
(single) Is the following description correct? The level of the MA5600T alarm can be divided into five
levels: critical, major, minor, warning, and cleared.
(single) In the process of installing the network management, how to confirm the ip address of the
Sybase database server running?
  • A. # ifconfig -a
  • B. # cat /opt/sybase/interfaces
  • C. # cat /etc/hosts
  • D. # less /etc/hosts
(single) After installing the sybase patch, which of the following commands can display the version
information of the sybase patch that has been installed?
  • A. 1>select @@version2>go
  • B. 1>select @@patch2>go
  • C. 1>version_help2>go
  • D. 1>ver_help2>go
(single) In the Solaris vi editor, how to discard the edited file and exit vi?
  • A. :quit!
  • B. :q
  • C. :exit
  • D. :q!
(single) In the Solaris environment, which of the following commands (parameters) is used to
unconditionally abort the process?
  • A. kill -7 pid
  • B. kill -8 pid
  • C. kill -9 pid
  • D. kill -10 pid
(single) Is the following description correct? The ADSL port can only allow further operations on the
port after the port is unblocked.
