Huawei h13-624 practice test
HCIP-Storage V5.0 Exam
Page 1 out of 49. Viewing questions 1-15 out of 731
(multiple choice) The daily inspection performance indicators of the big data storage system include:
A. Disk utilization
B. CPU utilization
C. memory utilization
D. node throughput
A, B, C, D
(multiple choice) The basic principles of daily maintenance of big data storage systems include:
  • A. Develop a reliable backup plan
  • B. Reserve spare parts on site for timely replacement in case of failure
  • C. Use the resources and software provided by the original manufacturer
(single choice) Which of the following is the correct power-on sequence of the Huawei OceanStor
9000 big data storage system?
  • A. Cabinet-->Switch-->KVM--->Node
  • B. Cabinet-->KVM-->Switch--->Node
  • C. Cabinet-->Switch-->Node--->KVM
  • D. Cabinet-->Node-->KVM--->Switch
(multiple choice) The value of Huawei OceanStor 9000 InfoTier is reflected in:
  • A. It can ensure the system's response speed to hot data access and improve the storage performance of the entire system.
  • B. Comprehensively utilize the cost advantages of different storage media to effectively reduce deployment and maintenance costs.
  • C. Improve system storage performance and realize intelligent data management.
  • D. Realize automatic file migration according to the corresponding relationship between file attributes and different storage devices, reducing the cost and complexity of manual management.
A, B, C, D
(single choice) Which load balancing method does the Huawei OceanStor 9000 InfoEqualize feature
not support?
  • A. CPU usage
  • B. User Group
  • C. Number of node connections
  • D. Node throughput
(single choice) In Huawei OceanStor 9000, which of the following is not an authentication method
supported by NFS sharing?
  • A. NIS authentication
  • B. LDAP authentication
  • C. Client IP address/host name authentication
  • D. Local user authentication
(single choice) The network connection is required before the initial configuration of the big data
system. The networking of Huawei OceanStor 9000 does not include:
  • A. Front-end business network
  • B. Back-end storage network
  • C. Management network
  • D. Heartbeat Network
(multiple choice) Which node types does Huawei OceanStor 9000 support?
  • A. P12
  • B. P25
  • C. P36
  • D. C36
A, B, C, D
(multiple choice) The network file sharing protocols supported by the NAS system mainly include:
  • A. FAT32
  • B. NTFS
  • C. NFS
  • D. CIFS
(Judgment) Through Huawei OceanStor 9000 Device Manager, we can view the real-time OPS
performance indicators of the system.
  • A. T
  • B. F
(single choice) Among the following OceanStor 9000 software features, which feature can provide file
system snapshots?
  • A. InfoLocker
  • B. InfoStamper
  • C. InfoProtector
  • D. InfoEqualize
(multiple choice) OceanStor 9000 adopts Erasure code technology to protect dat
a. If a site has 6 nodes,
And the customer wants to ensure that the data can be recovered even if three disks are broken in
one strip, the redundancy protection levels that can be adopted are:
  • A. 4+3:1
  • B. 6+3
  • C. 4+2
  • D. 12+3:1
(multiple choice) Which of the following is correct in IDC's description of the characteristics of big
data?
  • A. Volume
  • B. Variety-Diversity
  • C. Value-value density
  • D. Velocity-speed
A, B, C, D
(Multiple choice) The quota types supported by OceanStor 9000 InfoAllocator are:
  • A. Capacity quota
  • B. File quota
  • C. Calculate quota
  • D. Mandatory quota
(Judgment) FusionStorage Block uses a unique data block slicing technology and data based on DHT
Hash
The routing algorithm can evenly distribute the data of the volume to the fault domain of a larger
resource pool, so that each volume can obtain a larger
IOPS and MBPS performance also makes the load of each hardware resource relatively balanced.
  • A. T
  • B. F
