Huawei h13-611 practice test
HCIA-Storage V4.0 Exam
Last exam update: Apr 11 ,2025
Page 1 out of 33. Viewing questions 1-15 out of 489
SAN network-based data replication technology is a storage area network between front-end
application servers and back-end storage systems
Network (SAN), adding a layer of intelligent switches, the front end is connected to the server host,
and the back end is connected to the storage device.
A. TRUE
B. FALSE
What is the correct sequence of the overall reconstruction process?
1. Query all CKGs with CK falling on the faulty disk
2. Assign hot spare CK to all these CKGs
3. Update CKG information and release the reconstructed CK
4. Write the reconstructed data to the hot standby CK
5. Through the RAID algorithm, calculate the data on the failed disk based on the data on the normal
disk and the check disk
  • A. 1->2->5->4->3
  • B. 1->2->3->5->4
  • C. 5->1->2->3->4
  • D. 5->2->1->4->3
DAS is a storage architecture without scalability.
A. TRUE
B. FALSE
Which of the following is not an IP SAN component?
  • A. Storage device with iSCSI interface
  • B. twisted pair
  • C. NIC
  • D. FC switch
The following two descriptions are correct:
Description 1: Synchronous remote replication, when the primary storage fails, the amount of data
lost can be 0.
Description 2: When the host is a Linux-based file system, asynchronous remote replication must be
used.
  • A. description 1 and description 2 are correct
  • B. Description 1 pair, description 2 wrong
  • C. Description 1 wrong, description 2 pairs
  • D. description 1 and description 2 are wrong
Which of the following operating systems can access CIFS shares without installing additional
software?
  • A. Win7
  • B. Solaris
  • C. FreeBSD
  • D. AIX
Which of the following RAID levels has the lowest hard disk space utilization?
  • A. RAID 0
  • B. RAID 1
  • C. RAID 3
  • D. RAID 5
Deduplication and compression can only be enabled for Thin LUNs.
Resolution: Only thin LUN can enable deduplication.
The following are the characteristics of the clustered NAS storage architecture: (multiple choice)
  • A. Unified namespace, shared globally
  • B. High performance, multiple arrays concurrent I/O
  • C. Online expansion
  • D. can provide block-level storage
A. B. C
A device has only one WWNN number, but it can have multiple WWPN numbers.
Which ports in the FC switch can communicate with each other is determined by the zone.
The following describes RAID 10, which are correct? (Multiple choice)
  • A. RAID 10 is used in scenarios with high requirements for speed and fault tolerance
  • B. RAID 10 requires at least 4 member disks
  • C. In RAID 10, if two member disks in a subgroup fail, the data is read normally
  • D. In RAID 10, the data is first mirrored and then striped
A. B. D
When the RPO time requirement is at the minute level, the traditional tape backup method can be
used.
When the RTO requirement is within 10 minutes, the traditional tape backup method is not
recommended.
FTP is a very secure protocol with no security risks.
