Huawei h12-711 practice test
HCIA Security V3.0 Exam
Page 1 out of 34. Viewing questions 1-15 out of 503
The SIP protocol uses the SDP message to establish a session, and the SDP message contains the
remote address or multicast address
Digital envelope technology means that the sender uses the receiver's public key to encrypt the data
and then sends the ciphertext to the receiver.
After the firewall detects a virus, which of the following will release the virus?
  • A. Hit apply exception
  • B. Not a protocol supported by the firewall
  • C. The source IP hits the whitelist
  • D. Hit virus exception
How many IPSec SAs need to be established to encapsulate P packets using the AH+ESP protocol?
  • A. 2
  • B. 1
  • C. 4
  • D. 3
Which of the following VPNs cannot be used in site-to-Site scenarios?
  • A. SSL VPN
  • B. L2TP VPN
  • C. IPSec VPN
  • D. GRE VPN
IPv6 supports configuring the router authorization function on the device, verifying the identity of
the peer through digital certificates, and selecting legal devices.
An employee of a company accesses the internal web server of the company through the firewall.
The web page of the website can be opened by using a browser, but the reachability of the web
server is tested by using the Ping command, and it shows that it is unreachable. What are the
possible reasons?
  • A. The security policy deployed on the firewall allows the TCP protocol, but not the ICMP protocol
  • B. The web server is down
  • C. The security policy deployed on the firewall allows the HTTP protocol, but not the ICMP protocol
  • D. The interface of the firewall connecting to the server is not added to the security zone
Which of the following descriptions about digital fingerprints in digital signatures is wrong?
  • A. The receiver needs to use the sender's public key to unlock the digital signature to obtain the digital fingerprint.
  • B. It is the data obtained by the sender after calculating the plaintext information through the HASH algorithm.
  • C. The receiver will use the sender's public key to calculate the generated data fingerprint and compare it with the received digital fingerprint.
  • D. Digital fingerprints are also known as information digests.
Which of the following SSLVPN functions can and can only access all TCP resources?
  • A. Network expansion
  • B. Port Forwarding
  • C. web proxy
  • D. file sharing
When the company network administrator configures dual-system hot backup, (fill in the blank)
configure the status of VRRP backup group l as Active, and configure the virtual IP address as
10.1.1.1/24
<sysname>system-view
[sysname] interface GigabitEthernet 0/0/1
[sysname-GigabitEthernet0/0/l] ( ), the command to be typed in the blank is (please fill in the
complete command in all lowercase)
vrrp d 1
virtual-ip 10.1.1.1
active
To configure a NAT policy in command line mode, you need to use the .command ( ) in the system
view to enter the NAT policy configuration view. (all lowercase) (fill in the blank)
nat-policy
( ) means that the computer system has defects and deficiencies in the specific matters of hardware,
software, protocols or system security policies. (Chinese Standard Terminology) (fill in the blank)
Vulnerability
Multiple different ( ) cannot be added to the same interface on the firewall at the same time (fill in
the blank)
Safe area
In USG6000E, the initial priority of VGMP is ( ) (fill in the blank)
( ) is an "indirect intrusion attack. This attack mode is to virtually place a computer controlled by an
intruder between two communicating computers in a network connection through various technical
means. (fill in the blank)
Man-in-the-
middle attack
