Huawei h12-211 practice test
HCIA-Routing & Switching V2.5 Exam
Page 1 out of 22. Viewing questions 1-15 out of 317
As Shown in the following figure, the switch configuration information is as follows. Which of the
following statement about the network and configuration is/are true?
Router A
aaa
local-user test password cipher test local-user test service-type ppp
interface Serial1/0/0 link-protocol ppp
ppp authentication-mode chap
ppp pap local-user test1 password cipher test1
ip address 10.0.12.1 255.255.255.0
Router B
aaa
local-user test1 password cipher test1 local-user test1 service-type ppp
ppp authentication-mode pap
ppp chap user test
ppp chap password cipher test
ip address 10.0.12.12 255.255.255.0
  • A. The Authentication mode of the interface on Router A is CHAP.
  • B. Router A uses the user name "test1" and password "test1" to pass the interface authentication of Router B
  • C. The Authentication mode of the interface on Router B is PAP.
  • D. Router B uses the user name "test1" and password "test1" to pass the interface authentication of Router A
According to the topology and configuration of the interconnected interface of switches shown in the
figure, the data frame tagged with VLAN 10 can be forwarded correctly between two switches.
[LSW1]interface GigabitEthernet0/0/1
[LSW1-interface
GigabitEthernet0/0/1]port
link-type
trunk
[LSW1-interface
GigabitEthernet0/0/1]port trunk pvid vlan 20
[LSW1-interface GigabitEthernet0/0/1]port truck allow-pass vlan 10
[LSW2]interface GigabitEthernet0/0/1
[LSW2-interface
link-type
trunk
[LSW2-interface
GigabitEthernet0/0/1]port trunk pvid vlan 10
[LSW2-interface GigabitEthernet0/0/1]port truck allow-pass vlan 10
As shown in the figure the host has ARP cache. Host A sends a data packet to host B. Which of the
following are the destination MAC address and destination IP address of the data packet?
  • A. MAC –A, 11.0.12.1
  • B. MAC –B, 11.0.12.1
  • C. MAC –C, 11.0.12.1
  • D. MAC –C, 11.0.12.2
According to the configuration of the single-armed routing in the following figure, the administrator
department and finance department can communicate with each other even if proxy ARP is disabled
on subinterface of R1?
Which of the following can prevent host A and Host B from communicating with each other?
acl number 2000
rule 5 deny source 100.0.12.0 0.0.0.255
interface G0/0/1
traffic-filter outbound acl 2000
acl number 2000
interface G0/0/2
traffic-filter inbound acl 2000
acl number 2000
interface G0/0/1
acl number 2000
interface G0/0/3
As shown in the figure, which of the following network devices can be used to implement
communication between host A and Host B?
  • B. layer 2 Switch
  • C. Router
  • D. Hub
As shown in the figure, the administrator requires that all hosts cannot access the internet during
8:00 - 17:00 every day. In this case, which ACL rule needs to be bound to traffic-filter outbound in the
interface configuration of G0/0/1?
time-range am9topm5 08:00 to 17:00 daily
acl number 2001
rule 5 deny time-range am9topm5
acl number 2002
rule 5 permit time-range am9topm5
time-range am9topm5 08:00 to 17:00 Working-day
acl number 2003
time-range am9topm5 08:00 to 17:00 off-day
acl number 2004
As shown in Figure, Host A and Host B cannot communicate with each other?
As Shown in the figure, host A and host B cannot communicate with each other?
On the network shown in the figure, when planning traffic, the network administrator requires that
the data packet sent from host A to host B pass through G0/0/3 on the router, and the packets sent
from host B to host A pass through G0/0/4 on the router, which of the following command can be
used to meed this requirement?
Router A : ip route-static 10.0.12.5 255.255.255.252 11.0.12.2
Router B : ip route-static 10.0.12.1 255.255.255.252 11.0.12.5
Router A : ip route-static 10.0.12.5 255.255.255.252 11.0.12.6
Router B : ip route-static 10.0.12.1 255.255.255.252 11.0.12.1
Router A : ip route-static 0.0.0.0 0.0.0.0 11.0.12.2
Router B : ip route-static 0.0.0.0 0.0.0.0 11.0.12.5
Router A : ip route-static 0.0.0.0 0.0.0.0 11.0.12.6
Router B : ip route-static 0.0.0.0 0.0.0.0 11.0.12.1
The LACP Priority is shown in the figure. Switch A and Switch B adopt link aggregation in LACP mode,
All interfaces are added to link aggregation group (LAG), and the maximum number of active port is
set to 3.Which port of switch A is not an active port?
  • A. G0/0/0
  • B. G0/0/1
  • C. G0/0/2
  • D. G0/0/3
On the Network shown in the figure, two switches are connected through four links. COPPER
indicates the electrical interface and Fiber indicates the optical interfaace. Which of the following
interface can form an Eth-trunk?
  • A. G0/0/3 and G0/0/2
  • B. G0/0/3 and FE0/0/3
  • C. G0/0/2 and FE0/0/3
  • D. G0/0/2 and GE0/0/1
According to the figure, which of the following statements is true?
  • A. The IP address mask of host A is different from that of host B, therefore Host A & B cannot communicate with each other
  • B. Host A can successfully ping Host B
  • C. The broadcast address of Host A and Host B are the same
  • D. Host A and B can communicate with rach other only when the IP address of Host A and Host B have same masks.
As Shown in the figure, if Host A has ARP cauche of Host B, Host A can ping Host B?
On the network shown in figure, the host has ARP cache. Which of the following statement are true?
  • A. A static route needs to configured on the router. Otherwise , Host A and Host B cannot communicate with each other
  • B. Host A and B can communicate with each other
  • C. The following ARP cauche entry exist on HOST A 11.0.12.1 MAC-B
  • D. The following ARP cauche entry exist on HOST A 10.0.12.2 MAC-C
