HP hpe6-a72 practice test
Aruba Certified Switching Associate Exam
Page 1 out of 6. Viewing questions 1-15 out of 88
Place the OSI Layers in the correct order. Arrange them from least to greatest, starting with Layer 1 on
the top, and progressing to Layer 7 on the bottom.
What VSF command produces the above output?
  • A. show vsf member
  • B. show vsf link
  • C. show vsf topology
  • D. show vsf detail
https://techhub.hpe.com/eginfolib/Aruba/OS-CX_10.04/5200-6790/index.html#GUID-88F65EB4-C1F9-49C7-9FB2-F994AB9D0D8F.html
What are two available options as part of a DHCP offer message? (Choose two.)
  • A. SSID
  • B. DNS server IP
  • C. Subnet Mask
  • D. LLDP-MED
  • E. VLANID
What command will display the debug l2mac events?
  • A. show module L2MAC
  • B. show debug terminal
  • C. show debug buffer module L2MAC
  • D. show debug all
Switch-1 is not the root bridge. The ports shown are all the connected pointtopoint interfaces. What
Role (hidden by the blue rectangle) will be assigned to the Lag 1 interface?
  • A. Alternate
  • B. Backup
  • C. Root
  • D. Designated
Which option correctly describes a WAN network?
  • A. a group of computer resources that communicates between geographically separate location
  • B. the connection between two separate buildings in the same campus
  • C. a network of devices over long distances but limited to within a single ISP
  • D. compute resources that are networked locally over wireless
With what other technology does Half Duplex communication closely match?
  • A. a pair of fiber optic strands allowing transmit on one and receive on the other at the same time
  • B. a mobile phone call
  • C. point-to-point connections between two switches allowing concurrent transmit and receive
  • D. CB radio using push-to-talk
Which field in the IPv4 header indicates whether the IP packet carries TCP or UDP traffic?
  • A. Protocol
  • B. IHL
  • C. TTL
  • D. Identification
Which two statements accurately describe stacking with Aruba switches? (Choose two.)
  • A. A VSF stack is allowed between an AOS-CX 6300M and 6300F switches.
  • B. VSF is a core or aggregation layer stacking technology due to the high resiliency of sharing a single control plane.
  • C. The VSF feature is not compatible between AOS-CX and AOS platforms.
  • D. A VSF stack is allowed between an AOS 5400R and an AOS-CX 6400.
  • E. VSF and VSX are stacking option with the AOS-CX 8320. 8325. 8400. and 6400 models.
BE
What is the correct binary conversion of the last two hexadecimal characters of the physical address?
  • A. 1101 1000
  • B. 1110 1101
  • C. 1001 1111 0101 0011
  • D. 1000 1101 1110 1101
Match each network protocol to the correct server listening port. Not all answers will be used.
What command (output shown above) gives the optics serial number and part number information?
  • A. show interface physical
  • B. show interface transceiver
  • C. show inventory
  • D. show interface optics
https://techhub.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8162_wb_2920_mcg/content/ch11s05.html
Which Ethernet port combination does the Aruba 5400R ZL2 switch series support?
  • A. 10/100 Megabit Ethernet, Gigabit Ethernet, and 100 Gigabit Ethernet
  • B. Gigabit Ethernet, 25 Gigabit Ethernet, and 40 Gigabit Ethernet
  • C. 10/100 Megabit Ethernet, Gigabit Ethernet, 25 Gigabit Ethernet, and 100 Gigabit Ethernet
  • D. 10/100 Megabit Ethernet, Gigabit Ethernet, and 40 Gigabit Ethernet
https://www.arubanetworks.com/assets/ds/DS_5400Rzl2SwitchSeries.pdf
You need to remote into an AOS-CX switch using SSH in order to update the management IP address
for future connections. Unfortunately, you mis-configured the IP address and are now locked out of
the switch.
What command could you have issued before making changes that would have recovered the
original switch configuration after ten minutes?
  • A. checkpoint rollback 10
  • B. checkpoint auto 10
  • C. checkpoint auto confirm 10
  • D. boot system secondary 10
Which two options are the Layer 2 protocols? (Choose two.)
  • A. 802.1Q
  • B. IPSec
  • C. STP
  • D. RIP
  • E. 802.11af
AC
