HP hpe2-t36 practice test
Using HPE OneView Exam
Page 1 out of 13. Viewing questions 1-15 out of 195
A system administrator is HPE OneView network for a VMware server farm.
The administrator requires an environment adding a new VLAN to an upstream switch and VMware
vSwitch does not require a change at the Virtual Connect level regardless of the number of used
VLANs.
Click the setting that allows such behavior in HPE OneView.
Which hpe management solution contain smart update manager(SUM)?
  • A. HPE Service Pack for Prolient
  • B. HPE Synergy Image Streamer
  • C. HPE Integrated Lighout
  • D. HPE Onview global dashboard
You want to provision storage pools from hybrid storage array to an HPE Synergy frame using the
composer. The application is critical and requires high performance. Which settings allow you to
guarantee all flash service level for specific volume
  • A. Adaptive optimization for 3 par storage array.
  • B. Performance policy for nimple storage array
  • C. Scope for 3par storage array
  • D. Cache pinning for nimple storage arrays.
How do you provide high availability on HPE oneview virtual appliance?
  • A. Deploy hpe oneview on a hypervisor cluster configured with high availability
  • B. Deploy a redundant pair of composer configured to provide high availability
  • C. Install hpe oneview on two servers and link them with oneview global dashboard.
  • D. Install hpe oneview on two servers and enable built in high availability in settings.
What is the correct procedure to configure this network?
  • A. Create an uplink set without any uplink port and enable smart link
  • B. Create an uplink set without any uplink port and enable private network
  • C. Create an new network set and set purpose field to VM migration
  • D. Add the desired network to the internal network on the LIG
A Customer is concerned about the security of the simple network management protocol (SNMP).
What should you recommend to resolve the customers concern? Select 2
  • A. Use Encryption in SNMPv1
  • B. Use Secure Socket layer SSL in SNMPv3
  • C. Use encryption in SNMPv3
  • D. Use authentication in SNMPv3
  • E. Use transport layer security in SNMPv1
a customer requires a report containing firmware revision of interconnect module across their blade
system and synergy enclosures. Which management solution should you recommend?
  • A. iLO amplifier pack
  • B. HPE OneView Global dashboard
  • C. HPE OneView for VMware vcenter
  • D. HPE OneView virtual appliance
Where is HPE oneview for synergy deployed?
  • A. On a physical appliance- composer
A customer is trying to upload an additional SPP to the oneview appliance, but receives an error
message stating that there is not enough internal space available. What can the customer change on
the appliance to enable the upload?
  • A. Add a web server as an external respository
A customer need to check wheather shared infrastructure and Gen10 servers are aligned with SPPs
available in the oneview repositories. Which HPE oneview functionality can be used to fulfill the
customer requirements?
  • A. Server hardware report
  • B. Firemware compliance report
  • C. Health check
  • D. Firmware repository
An administrator selected firmware and OS drivers using smart update tools when installing a new
HPE Service pack for ProLiant. Which statement are true for theis administrator environment
  • A. Customer will be automatically detected and updated simulteniously.
  • B. By default only a new version of firmware/drivers will be installed
  • C. Firmware and OS drivers will always start immediately to be as fast as possible.
  • D. Firmware and OS drivers are updated without powering off the server hardware
What does the HPE oneview global dashboard provide?
  • A. Extends the unified management view across all of your data center
  • B. Offer the ability to manage non-hpe devices
  • C. Adds a layewr of security beyond what hpe oneview delivers on its own.
A customer plan to manage their HPE Blade System c7000 enclosure using HPE OneView. What
information is required to add the enclossure to the HPE onvew appliance . Serlect 2
  • A. Gateway address
  • B. OA Credentials
  • C. iLO IP Address
  • D. Enclossure Group
  • E. DNS server address
You are designing a new deployment consisting of HPE Proliant Gen 10 rack server and nimple
storage array. The hpe OneView virtual appliances will run on a esxi hypervisor.. which data
protection method is recommended to backup and be able to restore your appliances in case of
catrostopic failure.
  • A. Create regular backup files and store than to an off-appliance location.
Which Action is required to enable automated SAN zoning with HPE oneview 5.x and FC switches
  • A. Add supported SAN manager
