HP hpe0-v17 practice test
Creating HPE Data Protection Solutions Exam
Last exam update: Jan 29 ,2025
Page 1 out of 6. Viewing questions 1-15 out of 76
You are organizing a Proof-of-Concept (POC) for your customer for their new data protection solution
based on Commvault technology in combination with HPE Nimble storage and HPE StoreOnce
backup targets.
The customer asks you to demonstrate the configuration options for deduplication within the
Commvault solution
is this a location where you can modify the deduplication parameters?
Solution: Navigate lo the Agents section and show the different parameters inside the Backup.
Archive, Normalization and Replication agents
  • A. Yes
  • B. No
You are organizing a Proof-of-Concept (PCX:) for your customer for Ihetr new data protection solution
backup targets.
The customer asks you to demonstrate the configuration options for dedupllcation within the
Commvault solution Is this a location where you can modify the dedupllcation parameters?
Solution:Access the Advanced Client Properties screen under Client Computers
  • A. Yes
  • B. No
Is this a supported integration with StoreOnce Catalyst?
Solution: Microsoft SharePoint
  • A. Yes
  • B. No
Does this option describe aspects of a valid Disaster Recovery (DR) plan component?
Solution: You might start a DR plan by denning downtime and data loss targets, because this can help
determine the type of solution that is best for you
  • A. Yes
  • B. No
Does this option describe aspects of a valid Disaster Recovery (OR) plan component?
Solution: When denning corporate personnel responsibilities, you typically exclude C-level executives
  • A. Yes
  • B. No
Is this a reason why your customer might choose the HPE Apollo 4510 systems instead of the HPE
Apollo 42O0 system?
Solution: The Apollo 4510 system has a higher density chassis, and so can host more drives with
more backup capacity
  • A. Yes
  • B. No
Is this a reason why your customer might choose the HPE Apollo 4510 systems Instead of the HPE
Apollo 4200 system?
Solution:The Apollo 4200 system is deployed with veeam Backup & Replication Standard Edition,
while the 4510 system runs the Enterprise Edition for a more extended feature set
  • A. Yes
  • B. No
Is this a valid statement regarding Commvault components?
Solution: For larger environments where high availability Is critical, the CommServe server can be
clustered
  • A. Yes
  • B. No
Solution: A Client Is a software module that is installed on a client computer to protect a specific type
of data
  • A. Yes
  • B. No
You plan to use the HPE Storage Sizing Tool for an HPE backup environment, as shown In the exhibit
Instead of manually entering all gathered information, you want to use the Import option for fast and
efficient sizing of a backup environment.
is this a tool that generates data that can be imported to the HPE Storage Sizer Tool?
Solution:Is this a tool that generates data that can be imported to the HPE Storage Sizer Tool?
NinjaProtected+
  • A. Yes
  • B. No
You plan to use the HPE Storage Sizing Tool for an HPE backup environment, as shown in the exhibit
instead of manually entering all gathered information, you want to use the import option for fast and
is this a tool that generates data that can be imported lo the HPE Storage Sizer Tool?
Solution: DD Analzer
  • A. Yes
  • B. No
A customer contacts you tor assistance with performance troubleshooting of Ihelr backup
environment because over the last few days they notice Increasing times tor backup completion They
see no apparent reason for this, since the data volume to be backed up did not change unusually
compared to the previous days and weeks.
You also notice that the deduplication ratio, historically steady at about 20:1. is now gradually
declining
Is this a potential cause or the problem?
Solution:There might be a network bottleneck, which could increase backup times Verify the
network traffic.
  • A. Yes
  • B. No
A customer contacts you for assistance with performance troubleshooting of their backup
environment because over the last few days they notice Increasing times tor backup completion.
They see no apparent reason for this, since the data volume to be backed up did not change
unusually compared to the previous days and weeks.
declining
Solution:Ransomware is encrypting data, making the dally incremental backups grow and lowering
the deduplication ratio due to new content.
  • A. Yes
  • B. No
environment because over the last few days they notice increasing times for backup completion They
declining
Is this a potential cause of the problem?
Solution:Ransomware is encrypting data, making the dairy incremental backups grow and lowering
  • A. Yes
  • B. No
You organize a workshop for your customers IT team to handover a newly deployed backup solution
based on HPE StoreOnce backup targets with Veeam as the backup application
Is this an important best practice for this scenario?
Solution:Use HW snapshot integration in the Job advanced properties it is much raster and has
lighter impact on the production VMs to be hacked up.
  • A. Yes
  • B. No
