HP hpe0-v13 practice test
Designing HPE Software-Defined Infrastructure Solutions Exam
Last exam update: Jan 29 ,2025
Page 1 out of 6. Viewing questions 1-15 out of 87
Is this a way to help a customer automate deployment of workloads on bare metal?
Propose an HPE Composable Rack solution and tell the customer to use cluster management to
deploy the workloads.
  • A. Yes
  • B. No
Does HPE help customers deploy OpenShift Container Platform on HPE Synergy in this way?
provides Docker images, available through Docker Hub, which are optimized for running on HPE
Synergy and OCP
  • A. Yes
  • B. No
https://www.li9.com/wp-content/uploads/2018/10/OpenShift-on-Synergy-Reference-Architecture-
181015.pdf
You are planning a Red Hat Open Container Platform (OCP) deployment on HPE Synergy, following
the HPE R
Is this a license that you should attach to a worker node?
a Red Hat Enterprise Linux Server license based on the number of processors on the node
  • A. Yes
  • B. No
A customer has an HPE FlexFabric data center network, which was working correctly. Then the
customer added VMware NSX, and now VM-to-VM traffic in logical networks is not being forwarded
by the network infrastructure.
Could this be the issue?
The MTU on the VXLAN transport VLAN on the FlexFabric switches is smaller than that used by the
VXLAN transport.
  • A. Yes
  • B. No
https://docs.vmware.com/en/VMware-NSX-Data-Center-for-vSphere/6.3/com.vmware.nsx.install.doc/GUID-2FA9D4DE-56C0-40A4-A085-2FCE502A87B9.html
The FlexFabric switches are not configured with an expanded VLAN set to match the VNIs in logical
switches.
  • A. Yes
  • B. No
Is this a characteristic that a platform should provide to help it support and scale up database that
supports both OLTP and OLAP workloads?
high memory capacity
  • A. Yes
  • B. No
storage capacity optimized over storage performance
  • A. Yes
  • B. No
You are deploying HPE FlexFabric switches in a data center in which a customer uses VMware NSX. Is
this something that you should check on the FlexFabric switches?
ToR switch ports that connect to ESXi hosts permit the NSX transport VLAN ID.
  • A. Yes
  • B. No
https://assets.ext.hpe.com/is/content/hpedam/a50000685enw
Is this something that you should check on the FlexFabric switches?
ToR switch ports that connect to ESXi hosts permit the ID associated with every VXLAN in NSX.
  • A. Yes
  • B. No
Your customer is struggling to make their data center, which is already 70% virtualized, more
automated and sofware-defined. IT resists further virtualization due to the special requirements of
some workloads.
Is this an approach that you should recommend to decision makers for meeting their goals?
Use OneViews templates and Unified API to treat both virtual and physical infrastructure as fluid
resource pools.
  • A. Yes
  • B. No
Is this a use case or benefit of HPE Recovery Manager Central RMC-V?
automate cloning VMs and attaching their virtual disks to a volume stored on HPE 3PAR
  • A. Yes
  • B. No
Is this how the Composable Fabric handles traffic at Layer 2?
It sees if the traffic matches an affinity and forwards the traffic on a dedicated path for that affinity.
  • A. Yes
  • B. No
If the traffic does not match an affinity, forward the traffic on a path calculated for such traffic.
  • A. Yes
  • B. No
https://assets.ext.hpe.com/is/content/hpedam/a00042387enw
It uses MAC forwarding table to find the correct forwarding port.
  • A. Yes
  • B. No
Is this a use case for deploying Microsoft Storage Spaces Direct on HPE infrastructure?
creating a link between a Microsoft Hyper-V environment and Nimble virtual volumes
  • A. Yes
  • B. No
