HP hpe0-s58 practice test
Implementing HPE Composable Infrastructure Solutions
Last exam update: Aug 29 ,2026
Page 1 out of 7. Viewing questions 1-15 out of 97
During an initial setup of a Synergy environment, an integrator needs to enable or disable
authorized Service access.
What will be the outcome when the integrator disables this service?
  • A. Authenticated administrators will be unable to make changes to the system
  • B. Authorized users will be unable to generate a support dump
  • C. Authenticated administrators will be unable to access the system
  • D. Authorized support will be unable to diagnose the system
https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c05098314 (62)
A customer has the following configuration:
Frame 1
Bay 1 HPE Synergy 12Gb SAS Connection Module
Bay 2
Bay 3 HPE Virtual Connect SE 40 GB F8 Module
Bay 4 HPE Synergy 12GB SAS Connection Module
Bay 5
Bay 6 HPE Synergy 10 Gb Interconnect Link Module
Frame 2
Bay 2
Bay 3 HPE Synergy 10Gb Interconnect Link Module
Bay 4 HPE Synergy 12Gb SAS Connection Module
Bay 5
Bay 6 HPE Virtual Connect SE 40Gb F8 Module
How many more frames can the customer add to their Synergy composable fabric? (Note:
Enter your answer in the answer field below.)
  • A. Frame 1 Bay 2 HPE Virtual Connect SE 100Gb F32 Module for Synergy (867796-B21) Frame 1 Bay 5 HPE Virtual Connect SE 16Gb Fibre Channel Module for Synergy (779227-B21) Frame 2 - Bay 2 Brocade 16Gb/24 Power Pack+ Fibre Channel SAN Switch Module for HPE Synergy (K2Q86A) Frame 2 Bay 5 HPE Synergy 4820C 10/20/25Gb Converged Network Adapter (876449- B21)
  • B. Frame 1 Bay 2 HPE Virtual Connect SE 100Gb F32 Module for Synergy (867796-B21) Frame 1 Bay 5 HPE Virtual Connect SE 16Gb Fibre Channel Module for Synergy (779227-B21) Frame 2 Bay 5 HPE Synergy 4820C 10/20/25Gb Converged Network Adapter (876449- B21)
In a 3-frame HPE Synergy environment, how should an integrator place the image Streamer
modules to allow for redundancy to all of the management connections?
  • A. one Image Streamer module in frame 2, and a second Image Streamer Module in frame 3 (2 total)
  • B. two Image Streamer modules in frame 2, and two Image Streamer modules in frame 3 (4 total)
  • C. one Image Streamer module in each Synergy frame (3 total)
  • D. two Image Streamer modules in frame 1 (2 total)
https://www.karma-group.ru/upload/iblock/2be/synergy_image_streamer.pdf (page 7)
What must an integrator do before an existing cluster can be imported to the HPE
Composer?
  • A. The vCenter Server must be integrated with the HPE Composer
  • B. The cluster must be vSAN enabled
  • C. The HPE Composer must have at least two management interfaces to connect to the cluster
  • D. The cluster must be enabled for HPE Composer integration
How should an integrator pair interconnect bays to set up redundant fabrics in an HPE
Synergy 12000 Frame?
  • A. Interconnect bays 1 and 2; bays 3 and 4; bays 5 and 6.
  • B. Interconnect bays 1 and 6; bays 2 and 5; bays 3 and 4.
  • C. Interconnect bays 1 and 4; bays 2 and 5; bays 3 and 6.
  • D. Interconnect bays 1 and 3; bays 2 and 4; bays 5 and 6.
https://h20195.www2.hpe.com/v2/GetPDF.aspx/c04815113.pdf
An integrator needs to add an FCoE connection to the server profile, but the FCoE
connection type is not available.
What is the likely cause of this issue?
  • A. FCoE capable interconnect modules are not installed in the Synergy frame
  • B. Defined FCoE network is not associated with a SAN or does not have VLAN Id defined
  • C. A FCoE connection is not available, as there is no LIG configured for FCoE connectivity
  • D. The FCoE connection has not been added as a Fibre Channel connection within a server profile
An integrator is installing three Synergy frames in different locations for a customer. As part
of the installation, the customer requests a single monitoring dashboard that shows the
current hardware status, warranty status, and open support cases of all three frames.
Which configuration steps must the integrator perform to provide the customer with this
functionality?
  • A. Enable Remote Support and Insight Online Integration in the Composer UI
  • B. Install Insight Remote Support Advanced, and integrate it with HPE Global Dashboard
  • C. Configure OneView with iLO Amplifier pack
  • D. Activate iLO Federation on all installed compute nodes
What are valid uses for an IPv4 address pool when configuring an HPE Synergy solution?
  • A. assignment of IP addresses for NICs in an operating system
  • B. assignment of IP addresses for Composer appliances
  • C. assignment of IP addresses for PXE booting to a deployment server
  • D. assignment of IP addresses for interconnect modules
  • E. assignment of IP addresses for iLOs
D,E
https://techlibrary.hpe.com/docs/synergy/shared/setup_overview/index.html
A customer has the following HPE Synergy solution:
two HPE Virtual Connect SE 32Gb Fibre Channel (FC) modules in each time
two HPE Virtual Connect SE 40GB F8 modules
four HPE Synergy 10Gb Interconnect Link Modules
Click the menu option the integrator should use to add more uplinks ports from HPE Virtual
Connect SE 32 Gb FC modules to SAN uplink set.
https://h20195.www2.hpe.com/v2/GetPDF.aspx/c04815258.pdf
Which policy can an integrator apply when creating a datastore using HPE OneView for
vCenter Server?
  • A. Data at Rest encryption policy
  • B. Round Robin load balancing policy
  • C. Recovery Manager Central policy
  • D. virtual machine Restart policy
An integrator prepares deployment documents with the list of all the hardware and software
components. The integrator also needs a list of all infrastructure services deployed, with the
functionality described.
Which services are provided by the vCenter Server component and should be placed in the
report? (Choose two.)
  • A. Auto Deploy
  • B. Single Sign-On
  • C. Update Manager
  • D. Lookup Service
  • E. Certificate Authority
C,D
A customer needs to evaluate Image Streamer as Proof-of-Concept (PoC) in a test and
development tab environment.
At a minimum, what does a Synergy integrator need in order to support this requirement?
  • A. a three-frame environment with redundant composer and Image Streamer appliances
  • B. a single frame with single composer and Image Streamer appliances
  • C. a two-frame environment with single composer and Image Streamer appliances
  • D. a single frame with redundant Image Streamer appliances
Which component of the HPE Synergy solution should you use to set the firmware/driver
baseline and the installation method for Synergy Compute nodes?
  • A. Composer
  • B. Smart Update
  • C. Image Streamer
  • D. Global Dashboard
https://support.hpe.com/hpsc/doc/public/display?docId=c05212310
Which storage solution can be used for volume provisioning using HPE Composer?
  • A. MSA 2040
  • B. HPE StoreEasy 1560
  • C. HPE 3PAR StoreServ
  • D. HPE XP7 Storage
https://www.karma-group.ru/upload/iblock/30b/hpe_synergy_composer.pdf
What is the purpose of the OmniStack Accelerator card installed in HPE SimpliVity
platform?
  • A. It performs inline data efficiency processing and deduplication
  • B. It provides very fast SSD capacity for demanding workloads
  • C. It provides graphic acceleration for VDI infrastructure
  • D. It accelerates CPU processing within a virtual machine
https://assets.ext.hpe.com/is/content/hpedam/documents/a00026000-
6999/a00026728/a00026728enw.pdf
