Page 1 out of 10. Viewing questions 1-10 out of 93
Which statement describes the results of this command: vault kv list secret/test?
Check the status of a specific key/value secrets engine
List the existing key names at the secret/test path
Output all key/value secrets engines
Output all key names from all key/value secrets engine
B 7 votes
scodan92
7 months, 3 weeks ago
testing tt
Which of these options does not allow the creation of a root token?
By using batch tokens
By using another root token
The initial root token generated at the vault operator init time
By using vault operator generate-root with the permission of a quorum of unseal key holders
A 4 votes
Which of the following storage backends supports high availability?
Azure Storage Container
Manta
Amazon S3
Consul
D 4 votes
Which is not true of Vault tokens?
Vault tokens are the core method for authentication in Vault
Vault tokens are generated by every authentication method login
Vault tokens map to information including polices the token holder has, TTL and max usage, metadata, creation and last renewal time, and more
Vault tokens are required for every Vault call
D 3 votes
Which of the following are replication methods available in Vault Enterprise? (Choose two.)
Cluster sharding
Namespaces
Performance Replication
Disaster Recovery Replication
cd
Which of the following statements are true about Vault policies? (Choose two.)
The default policy can not be modified
You must use YAML to define policies
Policies provide a declarative way to grant or forbid access to certain paths and operations in Vault
Vault must be restarted in order for a policy change to take an effect
Policies deny by default (empty policy grants no permission)
ce
C 3 votes
E 3 votes
What information is required to revoke a Vault lease?
Secret ID
User ID
Lease ID
Token ID
C 3 votes
Why might an application be mapped to an identity entity?
To prohibit Vault administrators from revoking tokens associated with that application
To get around cloud license limitations
To allow an application deployed with multiple authentication methods have a consistent set of policies
To allow the same application in one cloud to access already provisioned Vault tokens for that application in another cloud
You manage two Vault dusters: vaultduster1.acme.corp and vaultduster2.acme.corp. You want to write a secret to the first Vaultcluster vaultcluster1.acme.corp and run vault kv put secret/foo value=bar. The command times out and the error references the Vault cluster, vaultcluster2.acme.corp. You run the command again with the following address flag: vault kv put -address=https://vaultcluster1.acme.corp secret/foo value=bar The command completes successfully. You find that the terminal session defines the environment variable VAULT_ADDR=https://vaultcluster2.acxe.corp:8200 Why was the second attempt successful?
Environment variables take precedence over flags
VAULT_CLUSTER_ADDR needs to be provided
Flags take precedence over environment variables
Vault listener is misconfigured
Where can you set the Vault seal configuration? (Choose two.)
testing tt
