Which statement is true about sending notifications with incident updates?
If you use multiple fabric connectors, all connectors must have the same notification settings.
Notifications can be sent only by email.
Notifications can be sent only when an incident is updated or deleted.
You can send notifications to multiple external platforms.
After generating a report, you notice the information you were expecting to see is not included in it. What are two possible reasons for this scenario? (Choose two.)
You enabled auto-cache with extended log filtering.
The logfiled service has not indexed all the expected logs.
The logs were overwritten by the data retention policy.
The time frame selected in the report is wrong.
bd
Which FortiAnalyzer tool can refer to the Cyber Kill Chain stages and allows you to identify which Fortinet products can protect you against new vulnerabilities?
Threat hunting SIEM table
Outbreak detection services
FortiSOC dashboards
FortiView Monitor top threats
Which statement about the FortiSIEM management extension is correct?
Allows you to manage the entire life cycle of a threat or breach.
Its use of the available disk space is capped at 50%.
It requires a licensed FortiSIEM supervisor.
It can be installed as a dedicated VM.
Why run the command diagnose sql status sqlplugind?
To list the current SQL processes running
To check what is the database log insertion status
To display the SQL query connections and hcache status
To view the current hcache size
What is the purpose of predefined report templates on FortiAnalyzer?
They can be customized to meet the needs of the intended audience.
They can be created by saving reports as templates.
They specify the layout used in reports.
They include the data used in reports charts.
Why must you wait for several minutes before you run a playbook that you just created?
FortiAnalyzer needs that time to parse the new playbook.
FortiAnalyzer needs that time to back up the current playbooks.
FortiAnalyzer needs that time to ensure there are no other playbooks running.
FortiAnalyzer needs that time to debug the new playbook.
Refer to the exhibit. Which statement is correct regarding the event displayed?
The security event risk is considered open.
The security risk was blocked or dropped.
The risk source is isolated.
An incident was created from this event.
a -
Which FortiAnalyzer feature allows you to use a proactive approach when managing your network security?
Outbreak alert services
FortiView Monitor
Threat hunting
Incidents dashboard
In Log View, you can use the Chart Builder feature to build a dataset and chart based on the filtered search results.
Similarly, which feature can you use for FortiView?
