Fortinet nse5-faz-6-4 practice test
Fortinet NSE 5 - FortiAnalyzer 6.4 Exam
Last exam update: Apr 11 ,2025
Page 1 out of 7. Viewing questions 1-15 out of 94
What does the disk status Degraded mean for RAID management?
  • A. One or more drives are missing from the FortiAnalyzer unit. The drive is no longer available to the operating system.
  • B. The FortiAnalyzer device is writing to all the hard drives on the device in order to make the array fault tolerant.
  • C. The FortiAnalyzer device is writing data to a newly added hard drive in order to restore the hard drive to an optimal state.
  • D. The hard drive Is no longer being used by the RAID controller
Which two statements are true regarding fabric connectors? (Choose two.)
  • A. Configuring fabric connectors to send notification to ITSM platform upon incident creation Is more efficient than third-party information from the FortiAnalyzer API.
  • B. Fabric connectors allow to save storage costs and improve redundancy.
  • C. Storage connector service does not require a separate license to send logs to cloud platform.
  • D. Cloud-Out connections allow you to send real-time logs to pubic cloud accounts like Amazon S3, Azure Blob , and Google Cloud.
Which two statement are true regardless initial Logs sync and Log Data Sync for Ha on FortiAnalyzer?
  • A. By default, Log Data Sync is disabled on all backup devise.
  • B. Log Data Sync provides real-time log synchronization to all backup devices.
  • C. With initial Logs Sync, when you add a unit to an HA cluster, the primary device synchronizes its logs with the backup device.
  • D. When Logs Data Sync is turned on, the backup device will reboot and then rebuilt the log database with the synchronized logs.
What is the purpose of using the Chart Builder feature on FortiAnalyzer?
  • A. In Log View, this feature allows you to build a dataset and chart automatically, based on the filtered search results.
  • B. In Log View, this feature allows you to build a chart and chart automatically, on the top 100 log entries.
  • C. This feature allows you to build a chart under FortiView.
  • D. You can add charts to generated reports using this feature.
What is Log Insert Lag Time on FortiAnalyzer?
  • A. The number of times in the logs where end users experienced slowness while accessing resources.
  • B. The amount of lag time that occurs when the administrator is rebuilding the ADOM database.
  • C. The amount of time that passes between the time a log was received and when it was indexed on FortiAnalyzer.
  • D. The amount of time FortiAnalyzer takes to receive logs from a registered device
What are analytics logs on FortiAnalyzer?
  • A. Log type Traffic logs.
  • B. Logs that roll over when the log file reaches a specific size.
  • C. Logs that are indexed and stored in the SQL.
  • D. Raw logs that are compressed and saved to a log file.
Which two statements express the advantages of grouping similar reports? (Choose two.)
  • A. Improve report completion time.
  • B. Conserve disk space on FortiAnalyzer by grouping multiple similar reports.
  • C. Reduce the number of hcache tables and improve auto-hcache completion time.
  • D. Provides a better summary of reports.
An administrator fortinet, is able to view logs and perform device management tasks, such as adding
and removing registered devices. However, administrator fortinet is not able to create a mall server
that can be used to send email.
What could be the problem?
  • A. Fortinet is assigned the Standard_ User administrator profile.
  • B. A trusted host is configured.
  • C. ADOM mode is configured with Advanced mode.
  • D. Fortinet is assigned the Restricted_ User administrator profile.
What can you do on FortiAnalyzer to restrict administrative access from specific locations?
  • A. Configure trusted hosts for that administrator.
  • B. Enable geo-location services on accessible interface.
  • C. Configure two-factor authentication with a remote RADIUS server.
  • D. Configure an ADOM for respective location.
https://docs.fortinet.com/document/fortigate/6.2.0/hardening-your-
fortigate/582009/system-administrator-best-practices
In Log View, you can use the Chart Builder feature to build a dataset and chart based on the filtered
search results.
Similarly, which feature you can use for FortiView?
  • A. Export to Report Chart
  • B. Export to PDF
  • C. Export to Chart Builder
  • D. Export to Custom Chart
https://community.fortinet.com/t5/FortiAnalyzer/Creating-a-Custom-report-from-
FortiView-Export-to-Report-Chart/ta-p/190154?externalID=FD40483
What two things should an administrator do to view Compromised Hosts on FortiAnalyzer? (Choose
  • A. Enable web filtering in firewall policies on FortiGate devices, and make sure these logs are sent to FortiAnalyzer.
  • B. Enable device detection on an interface on the FortiGate devices that are connected to the FortiAnalyzer.
  • C. Subscribe FortiAnalyzer to FortiGuard to keep its local threat database up-to-date.
  • D. Make sure all endpoints are reachable by FortiAnalyzer.
https://docs.fortinet.com/document/fortianalyzer/6.4.0/administration-
guide/137635/viewing-compromised-hosts
An administrator has moved FortiGate A from the root ADOM to ADOM1.
Which two statements are true regarding logs? (Choose two.)
  • A. Analytics logs will be moved to ADOM1 from the root ADOM automatically.
  • B. Archived logs will be moved to ADOM1 from the root ADOM automatically.
  • C. Logs will be presented in both ADOMs immediately after the move.
  • D. Analytics logs will be moved to ADOM1 from the root ADOM after you rebuild the ADOM1 SQL database.
https://community.fortinet.com/t5/Fortinet-Forum/FW-Migration-between-ADOMs/m-
p/32683?m=158008
Which two statements are true regarding high availability (HA) on FortiAnalyzer? (Choose two.)
  • A. FortiAnalyzer HA can function without VRRP. and VRRP is required only if you have more than two FortiAnalyzer devices in a cluster.
  • B. FortiAnalyzer HA supports synchronization of logs as well as some system and configuration settings.
  • C. All devices in a FortiAnalyzer HA cluster must run in the same operation mode: analyzer or collector.
  • D. FortiAnalyzer HA implementation is supported by many public cloud infrastructures such as AWS, Microsoft Azure, and Google Cloud.
https://help.fortinet.com/fa/faz50hlp/60/6-0-2/Content/FMG-
FAZ/4600_HA/0000_HA.htm?TocPath=High%20Availability%7C_____0
Which two statements are true regarding enabling auto-cache on FortiAnalyzer? (Choose two.)
  • A. Report size will be optimized to conserve disk space on FortiAnalyzer.
  • B. Reports will be cached in the memory.
  • C. This feature is automatically enabled for scheduled reports.
  • D. Enabling auto-cache reduces report generation time for reports that require a long time to assemble datasets.
https://help.fortinet.com/fa/faz50hlp/56/5-6-2/FMG-FAZ/2300_Reports/0025_Auto-
cache.htm
The admin administrator is failing to register a FortiClient EMS on the FortiAnalyzer device.
What can be the reason for this failure?
  • A. FortiAnalyzer is in an HA cluster.
  • B. ADOM mode should be set to advanced, in order to register the FortiClient EMS device.
  • C. ADOMs are not enabled on FortiAnalyzer.
  • D. A separate license is required on FortiAnalyzer in order to register the FortiClient EMS device.
FAZ/0800_ADOMs/0015_FortiClient%20and%20ADOMs.htm
