implementing cisco advanced call control and mobility services (classm)
Page 1 out of 17. Viewing questions 1-10 out of 170
A company has users that are logged in to hunt groups. However, there is a requirement for hunt group configurations to provide an option to turn on audible ringtones when calls to a line group arrive at a phone that is logged out and on a break. This ringtone alerts a logged-out user that there is an incoming call to a hunt list to which the line is a member, but the call does not ring at the phone of that line group member because of the logged-out status. Which action meets this requirement?
Configure the HLog softkey on the phone so that while a user is logged off, it plays an audible tone when a call is missed.
Set the service parameter Enterprise Feature Access number for hunt group logout and set up an access number.
Set the service parameter Party Entrance Tone to "True."
Configure the service parameter hunt group logoff notification and specify the name of the ringtone file.
An administrator is configuring Cisco UCM and the system to send *.webex.com traffic to a Cisco UCM Session Management Edition cluster. The administrator wants to limit which endpoints can reach *.webex.com. Which two items must the administrator configure for the SIP route pattern? (Choose two.)
calling party transformation
partition of the SIP route pattern
connected party transformation
called party URI transformation
destination SIP trunk of the SIP route pattern
A user reports that when they attempt to log out from the Cisco Extension Mobility service by pressing the Services button, they cannot log out. What is the most likely cause of this issue?
The Cisco Extension Mobility service has not been configured on the phone.
There might be a significant delay between the button being pressed and the Cisco Extension Mobility service recognizing it. It would be best to check network latency.
The user device profile has not been assigned to the user.
The user device profile is not subscribed to the Cisco Extension Mobility service.
Refer to the exhibit. A Cisco Unified Border Element continues to send 180/183 with the required: 100rel header to Cisco UCM, and the call eventually disconnects. How is the issue resolved?
Disable "SIP Rel1XX Options" and "Early Offer Support" on the SIP Profile Configuration Page in Cisco UCM.
Enable "SIP Rel1XX Options" and "Early Offer Support" on the SIP Profile Configuration Page in Cisco UCM.
Disable "Send send-receive SDP in mid-call INVITE" on the SIP Profile Configuration Page in Cisco UCM.
Enable "Early Offer support for voice and video calls" on the SIP Profile Configuration Page in Cisco UCM.
A users phone is already configured for Single Number Reach, and the user wants a feature to move an active call from a mobile phone to a desk phone and vice-versa. As an administrator, which additional configuration should be made to fulfill the users request?
Use Dialed Number Analyzer to determine if the user extension can dial the mobile phone.
Add the mobility key to the softkey template that the desk phone is using.
Check to make sure that the Resume softkey option appears on the desk phone.
Confirm that the desk phone is subscribed to Cisco Extension Mobility.
Refer to the exhibit. Users report that outgoing calls do not work on the new SIP trunk for outgoing calls. The solution consists of a Cisco UCM Cluster linked to a Cisco Unified Border Element where the SIP trunk is terminated. The provider required 10 digits. The logs show a line going toward the Cisco Unified Border Element. Which code snippet must be added to the configuration to meet the requirement?
request Invite sip-header modify
sip-header modify
request Invite sip-header Diversion modify
An engineer must configure call queuing under a Hunt Pilot. After the engineer receives the audio file that will be played to callers during queuing, which two steps should be taken to complete the configuration? (Choose two.)
Assign the uploaded audio file to Network Hold MOH Source & Announcements under Hunt Pilots Queuing section.
Upload the audio file in TFTP File Management via OS Administration GUI.
Assign the uploaded audio file to the hunting Line Group members User Hold MOH Audio Source.
Assign the uploaded audio file to the hunting Line Group members Network Hold MOH Audio Source.
Upload the audio file in MOH Audio File Management via CM Administration GUI.
ae
Refer to the exhibit. Within the North American Numbering Plan, gateways located in Ottawa, Canada and marked as YOW are assigned to the Calling Party Transformation CSS NANP_CgPTP, which contains partition NANP_calling_xforms. What is the calling-party number and the numbering type if the calling user +1613-555-1234 dials the number?
calling number 613-555-1234 and numbering type "subscriber"
calling number 011-1-613-555-1234 and numbering type "subscriber"
calling number 011613-555-1234 and numbering type "international"
calling number 613-555-1234 and numbering type "national"
Calls are not working when sent from a Cisco Unified Border Element to a service provider. After investigating the logs, the engineer notes that the Cisco Unified Border Element is sending the extension only. How is the issue addressed in the configuration?
voice class request sip-header diversion
sip-header contact modify
voice class request sip-header modify
request invite sip-header diversion modify
Which configuration element of a hunt group allows for changing Calling Party Transformations settings?
